10-29-2019, 05:37 PM | #1 |
Rep 10,473
Used BMW Trunk Mount ATM Unregistered with BMW, Teleservices and Professional Navigation. Part #84106836765 USA VIN ATM Perfect for keeping all online services with a NBT EVO Retrofit. Came from BMW with NBT EVO that was totaled but ATM is still active, so VIN will never conflict in Database. VIN number will be provided to buyer. Note NBT EVO unit MUST be coded to the same VIN as ATM. Neither NBT EVO unit, cabling or coding is included, though I can point you in the direction as to where those can purchased.. ATM VIN cannot be changed to continue working properly. Money Back Guarantee that this VIN ATM can be registered with BMW. After registration in your name, specific Online Services can be purchased at that point. Retrofitting and/or coding/recoding of NBT EVO most likely required to match ATM VIN and features. You MAY need new FSC codes in the NBT EVO HeadUnit as well. However, if you know what you are doing, an over the air software update should allow you to restore those FSC codes directly from BMW. Why not buy a used one one eBay or another source? Most ATMs are registered to their original owners and you cannot change without driving the (totaled) BMW with the totaled VIN to a BMW Dealer and show a BMW Genius your title for that specific VIN in YOUR name. Only then can the Account be moved to your name. Why that hassle? Because remember remote service can unlock door, even act as a key and start the car. It is essentially a key and so it follows the same tight legal restrictions proving ownership as a new key does. If you understand what this can do, you realize the potential of what this is and what it can do. It is a rare needle in a haystack as BMW often deletes branded title's VINs from its database of units that can use Connected Drive Services. https://www.realoem.com/bmw/enUS/par...;q=84106836765 Price includes shipping in USA. Battery Condition not guaranteed. It *MIGHT* need replacing. See Part 6 below. MSRP below $35 and available online for ~$25. Last edited by IK6SPEED; 11-08-2019 at 09:11 PM.. |
05-14-2020, 01:18 PM | #7 |
Rep 208
Drives: San Marino blue 435i Gc
Can someone point me in the right direction to getting connected drive services working. My hu has the vin of donor atm. I’m getting sos call malfunction and sos button doesn’t work. I’m thinking maybe an issue with wiring. Does anybody know the pinout or maybe someone that sells the correct harness for atm retrofit.
05-14-2020, 01:41 PM | #8 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
