BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding cruise control into LIMIT
proTUNING Freaks
      02-25-2020, 12:01 PM   #1
nl dutchy jay
Drives: F31
Hey guys!
After my F31 got broken into, and the entire nav stolen, I finally have it back. I immediately started coding it back to the options I previously had.
Unfortunately, I ran into a problem: somehow, I cannot (re)code my "SET" button on my steeringwheel to operate as a limiter.
I use ESYS and this is the problem I run into. The following lines I need to code:
KOMBI 3003 SLD_ENABLE
ICM 3000 SLD_Funktion aktiv
ICM 3000 C_Umschaltung_ACC_DCC zugelassen
ICM 3000 LDM_SET_Taste nur_SET__O
However, my vehicle only shows me the KOMBI and the C_Umschaltung_ACC_DCC zugelassen option. The other two options aren't even in the list to code. Needless to say, with coding those two, the button still acts as a cruise control button, and not as the LIMIT button.
Does anyone have a feint idea what can cause this? Or how I can solve this?
Thank you in advance!
      02-25-2020, 12:50 PM   #2
atzebmw
Drives: Tesla Model 3
This happens when you only search for exactly this value.
If you enter "SLD_FUNKTION" in the search above, you will find the value that is actually called C_SLD_FUNKTION.
I didn't find the last value either.
It works without it.
      02-25-2020, 01:10 PM   #3
nl dutchy jay
Drives: F31
Legend, I will try it tonight! Thank you so much for your help!
      03-04-2020, 06:45 AM   #4
nl dutchy jay
Drives: F31
Thank you again man, that totally worked! You saved me a trip to the local coder again!
It is the 2nd time you've greatly helped me. Is there any way I can buy you a beer or something? You got any donationlinks running?
      03-04-2020, 08:45 AM   #5
atzebmw
No problem.
No donation necessary.
I am happy if I could help.
coding, esys, lim, lim function, limiter
