BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Rough idle, weak acceleration - no CEL
      04-24-2020, 07:41 AM   #23
tardboi
Drives: 335i xDrive MSport
Well it's back today. Coolant -128c. No power. Same codes as before. 3 invalid signals + thermostat stuck open. Also code about reducing power.
      04-24-2020, 02:36 PM   #24
Bmwman325
Drives: 2015 MG CR 335 XI 6SP
My experience is when a sensor is giving you a crazy negative reading, the sensor is likely dead or the wire going to it is damaged. Track down where the sensor is. If its cheap and easy to replace start there. That wacky -128 is probably making the DME bug out. Also check your fuses, find what fuse runs the coolant temp sensor.
Wagner Competition Intercooler, ER Chargepipe, Fabspeed Catted Downpipe, Bootmod3 OTS Stage 2 93 oct
      06-02-2020, 11:05 AM   #25
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
2014 BMW 335i  [0.00]
Checking back in, did you get this sorted?
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff
Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser
Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327
      06-02-2020, 12:48 PM   #26
tardboi
Yes I think I edited it on to the OP. It was the transmission heat exchanger thermostat.
      09-09-2020, 08:30 AM   #27
rugbyfool89
Drives: F30 335i Sport
Do you have a part number for the transmission heat exchanger thermostat? I'm having similar issues...
      09-09-2020, 08:31 AM   #28
rugbyfool89
Do you have a part number for the transmission heat exchanger thermostat that was replaced? I'm having similar issues.
      09-09-2020, 05:17 PM   #29
tardboi
17217600550
(Unfortunately the thermostat alone cant be replaced)
During repair these broke:
17128570061
11537793373
Did you check the hidden menu for coolant temp? There is a extended warranty on one of the F30 thermostats; I dont think this is the one though.
