BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 PDC failure
      06-02-2020, 06:25 AM   #1
fifa_05
Drives: f30
F30 PDC failure
Hello eveyone.
I hava problem on this video.
PDC is seeing something but there is nothing behind.
Suddenly happen by itself, there is no accident, there is no action on bumpers.
I'm driving my 2012 sportline for 4 years.
what it could be?
https://vimeo.com/425096974
      06-03-2020, 12:23 AM   #2
fifa_05
Drives: f30
Up
      06-03-2020, 01:12 AM   #3
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Try cleaning out the rear sensors with some isopropyl alcohol; if they are dirty, they will go off intermittently.
      06-04-2020, 01:42 AM   #4
fifa_05
Drives: f30
I've tried already. But did not work.
      06-04-2020, 07:30 AM   #5
Poochie
Poochie's Avatar
Drives: 2016 M2
When one of mines when out, I used ISTA to narrow down which one was defective.
If it's not dirt causing the fault, I guess run a code reader and see what you can find.
      06-05-2020, 02:19 AM   #6
fifa_05
Drives: f30
Thanks. My mechanic has ista.
Can you explain the ISTA menu?
How can he control the PDC sensors on ISTA?
He had tried "all vehicle test" and there was no issue code.
      06-05-2020, 12:04 PM   #7
Poochie
Poochie's Avatar
Drives: 2016 M2
Under "Text Search" type in "ABL PDC" and it takes you the menu to run a test on the PDC, the rest is self-explanatory..
