04-21-2018, 09:38 AM | #5 |
Rep 808
You'll want to move up a profile or go to a 245 front 275 rear on those profiles.
Also if you have the option I'd do a higher offset on the rear wheels like ET40. But if you're buying the set used for a good deal, then yes the specs are pretty good |
04-21-2018, 09:48 AM | #6 |
Rep 2,771
They'll fit. As others have stated though, you'll probably need to up the tire sizes. Stock X drive sits pretty high up and running tires a full profile lower than stock is going to make it even more noticeable. It will be 4x4 style. I'd recommend lowering the car first, or getting all taller tires.
Here's a pic of my setup on stock suspension. 19x9.5 et27 in the rears at the time. 255/35/19 all around. These pics are mainly so you can see fitment of the rears. Your fronts won't be ass aggressive as mine is. |
04-21-2018, 10:50 AM | #7 |
Rep 10,473
classyfast670.50 |
05-01-2018, 07:07 AM | #8 |
Rep 2,219
05-01-2018, 10:33 AM | #9 |
Rep 10,473
No issues
classyfast670.50 |
05-02-2018, 12:55 AM | #10 |
Rep 6,659
It'll fit but as mentioned wont look good height wise
alohasurftoad3078.00 |
05-02-2018, 10:32 AM | #11 | |
Rep 10,473
As OEM 19” size are 26.1/26.0”, 25.3”/25.5” will give you 0.35” in front and 0.25” height difference in rear (or less), your description of not looking good is highly overblown. If car is lowered even that can be accounted for. Last edited by IK6SPEED; 05-02-2018 at 10:37 AM.. |
classyfast670.50 |
05-02-2018, 01:24 PM | #12 | |
Rep 6,659
Its my opinion, you do not need to agree. I don't like the way it looks, you do and that's completely okay |
