05-03-2020, 08:39 PM | #1 |
Rep 1
REMOVING REAR AXLE (RWD 335i)
I may have killed my passenger rear axle doing launches. Now it is time to replace and I cant find anything on how to detach the axle from the differential. Does it just pull out once removed from the hub? Or do I need another specialty tool? Any advice is appreciated, thanks in advance
05-03-2020, 08:48 PM | #2 | |
Rep 3,958
https://www.newtis.info/tisv2/a/en/f...shaft/GzqfC0Mc |
Fudz26.50 |
05-03-2020, 10:17 PM | #3 | ||
Rep 288
03-03-2021, 07:29 PM | #4 |
Rep 2
I just did mine - I put a big hose clamp around the fat part of the axle near the diff, and slipped a small, flat right angle pry bar I have to pull nails under it, so the long part is towards the center of the car. Then I took a long pry bar, and wedged it between the little pry bar and the diff, and applied pressure, it slipped right out.
TF |
cv axle, differential, output shaft |
