BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Cabin Filter - MicronAir
      05-13-2019, 02:32 PM   #1
Mr Podman
Drives: 2015 F32 Coupe
I just changed the cabin filter on my 2015 F32. Quite a PITA compared to my E46 (that could be changed in 3 minutes with no tools).
Tools:
10mm socket.
Torx 20 driver.
I used a made-in-Germany MicronAir cabin filter that I bought for $20.25 from Pelican Parts. It worked great and is easily half the price compared to the alternatives. I used MicronAir filters for 15 years with my E46.
Tips,
Pay attention to direction of air flow marked on the filter.
Don't disconnect the condensate line.
A DIY video I found useful:
https://www.youtube.com/watch?v=4qoUTUWvB3Y
podman
      05-15-2019, 07:14 AM   #2
Wolfus Aurelius
Wolfus Aurelius's Avatar
83
Drives: 2015 BMW 328i (gold/cream)
Tools:
10mm socket.
Torx 20 driver.
Tips,
podman
I planned to do it in a month or so. My idea is to slide the passenger seat all the way back, and put a rug or a thick robe across the door sill so I can lie on it without cracking a rib.
      05-15-2019, 07:41 AM   #3
chowser51
chowser51's Avatar
Drives: 2018 BMW F33 430i xDrive
Easy for me. After numerous resistor changes in my Oldsmobile, I just lay down and stick my feet up and work upside down. Even easier in my BMW when I put the top down.
      05-15-2019, 07:55 AM   #4
bimmer456
Drives: 340i
Micro air is an oem for many brands. Not sure if BMW uses them but they are pretty good compare to the crap they sell at autozone. With cabin air filters quality matters just like with the HVAC filters I uses in my furnace. I use the better ones at Home Depot but may switch to 3M filtrete for the same price. Cabin air filters are a pain to swap on the F30 vs tooless design in the Mini and every other car.
      05-15-2019, 08:18 AM   #5
Mr Podman
Smart.
I think I did crack a rib. I'm not kidding.
podman
      05-15-2019, 08:40 AM   #6
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
You can tell in the video that the car is on a lift. I change my filter when I'm rotating my tires, with the right side of the car jacked up. It's not as easy as it would be on a lift, but a lot better than on the ground.
      05-15-2019, 09:18 AM   #7
Fliplegend
Fliplegend's Avatar
Drives: 2015 328xi
Just did this last week except I got mine from FCP Euro. Wasn't too bad. Original filter below with 31K.
15' 328ix Mineral White | Saddle Brown | Luxury | SAT
      05-15-2019, 03:48 PM   #8
Wolfus Aurelius
83
Then it makes sense for me to have my regular mechanic do it when he is changing oil and rotating tires.
      05-15-2019, 05:23 PM   #9
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
As long as the charge is reasonable...dealers want like $200 to replace the cabin filters.......
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|
      05-15-2019, 05:27 PM   #10
Billfitz
Billfitz's Avatar
Only the ones on major thoroughfares, because that's highway robbery.
      05-16-2019, 02:23 AM   #11
Mike_BMW
Drives: 2014 320iX SE
Just bought a filter and plan to do this at the weekend! Hopefully no ribs will be broken
      05-16-2019, 10:41 AM   #12
Wolfus Aurelius
83
What is it, a 1/2 hour job? My mechanic charges about $70/hour labor, and I can bring him the filter.
      05-16-2019, 11:00 AM   #13
Mr Podman
Your mechanic gets the air flow direction wrong 50% of the time either because he doesn't know it matters or he doesn't think it matters.
podman
      05-16-2019, 12:02 PM   #14
Billfitz
Billfitz's Avatar
So copy the video, take your laptop with you for your appointment and he can see how it's done. Unless it's a German car specialty shop, in which case he should already know.
      05-17-2019, 10:41 AM   #15
Wolfus Aurelius
83
Yup; he's been working on MBs, BMWs, and Audis for a long time.
