05-15-2019, 02:23 PM | #155 | ||
Rep 891
https://www.bimmerpost.com/forums/sh...php?p=20511232 To clarify, most have not used spacers for the LCA install from what I have seen.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 05-15-2019 at 02:55 PM.. |
05-26-2019, 04:03 AM | #156 |
Rep 3,947
Are you guys just using the hardware from the M3 headlight leveling rod and your original headlight leveling rod or are you using the completely new M3 headlight leveling rod?
05-26-2019, 06:52 AM | #157 |
Rep 241
I have the LCAs installed already. I am on stock msport suspension and looking to upgrade shortly. does anyone have the LCAs on a lowered car that does not rub? can you give insight to your set up?
05-26-2019, 11:47 AM | #159 | |
Rep 241
05-28-2019, 11:57 AM | #160 |
Rep 3,947
I just picked up the car after installing the M3 wishbones and tension struts.
Car: 2014 BMW 335i RWD M Sport Suspension modifications: M Performance Suspension and OE BMW camber correction hubs (-0.5) Total camber on the front axles with the M3 wishbones and tension struts installed are: Front driver's: -2.4 degrees Front passenger: -2.3 degrees. |
MacklinUSOB518.00 |
07-14-2019, 02:03 PM | #161 |
Rep 73
Polo08816,
After installing the F80 LCA and TS arms would you say it was worth it? I've also got a 2014 M sport 335i but I've installed solid aluminum rear subframe mounts and the M Performance suspension kit. The rear response is outstanding and exactly what I was after but it's made the front rubbery steering response stand out that much more. I'm contemplating this or the ball joint replacement for the hydro bushing in the front of the TS. We also have a 2012 X3 35i and I find it's front end steering response is better than the 335i and before anyone asks I've inspected for leaking fluid and the condition of the hydro bushing and everything appears factory fresh on my 30,000 mile car. I run as close to zero toe in as I can get away with. This alignment setting made it a bit more responsive and improved tire wear but still doesn't get done what I'm after. I ditched the run flats long ago and run Michelin AS3. My last set of PSS didn't make it 15,000 miles and ended up with some close hydroplane calls so went with an all rounder. Appreciate your insight as I contemplate which mod to do. |
07-14-2019, 03:15 PM | #162 |
Rep 785
Check out this thread Re the control arm monoball mods
https://f30.bimmerpost.com/forums/showthread.php?t=1624895 Folks who have done it are pretty happy with the improvement in steering. Might be just what you are looking for QUOTE=E36M3;25026100]Polo08816, After installing the F80 LCA and TS arms would you say it was worth it? I've also got a 2014 M sport 335i but I've installed solid aluminum rear subframe mounts and the M Performance suspension kit. The rear response is outstanding and exactly what I was after but it's made the front rubbery steering response stand out that much more. I'm contemplating this or the ball joint replacement for the hydro bushing in the front of the TS. We also have a 2012 X3 35i and I find it's front end steering response is better than the 335i and before anyone asks I've inspected for leaking fluid and the condition of the hydro bushing and everything appears factory fresh on my 30,000 mile car. I run as close to zero toe in as I can get away with. This alignment setting made it a bit more responsive and improved tire wear but still doesn't get done what I'm after. I ditched the run flats long ago and run Michelin AS3. My last set of PSS didn't make it 15,000 miles and ended up with some close hydroplane calls so went with an all rounder. Appreciate your insight as I contemplate which mod to do.[/QUOTE] |
07-14-2019, 03:25 PM | #163 | |
Rep 3,947
There's no comparison between front end steering response of the 335i vs the X3 35i. Did you install the solid aluminum rear subframe mounts yourself or did you have a shop do it? If it was a shop, how much was the labor? Last edited by Polo08816; 07-14-2019 at 03:48 PM.. |
07-15-2019, 04:36 AM | #164 | |
Rep 1,291
I switched to millway monoball for the tension struts, and very happy with it, significantly more stable in curves and I can't find any increase in NVH.
(I'm on F30 stock LCA and F30 TS with upgraded bushings) http://www.millway.se/front-control-...w-f2x-f3x.html Quote:
2017 M550i | Sophistograu
07-15-2019, 12:17 PM | #165 |
Rep 73
Polo08816,
I did all the work myself. I have a master ball joint remover kit I used to press out the OEM rubber subframe mounts. I would give you a picture and the name but I'm writing from Kabul Afghanistan at the moment. This deployment will wrap up 18 months in country in the last 30 months. Job wasn't hard to do, just time consuming. If you do it make sure you buy a new driveshaft nut and you have the large wrench to remove the old one and install the new one. It's got anaerobic sealer already on the threads from the factory so there is no reusing the old one. The initial break away torque from the sealer on the nut was the most difficult part up on jack stands. The rest was lowering everything enough to use my ball joint remover kit to press out the old and install the new Turner pieces. Make sure you clock the new ones correctly or they won't seat all the way. That part wasn't clear and glad I caught it in time because once their seated they are an interference fit and would be difficult to remove and reclock. The online factory service manual details dropping the subframe very well. The other thing I did while doing the solid mounts was the F32 brace install documented here: https://f30.bimmerpost.com/forums/sh...78&postcount=7 Lancelot, Appreciate the feedback on your monoball experience with the original arms. Both the Turner and the Dinan ones appear to be a version of the OEM monoballs used in my '97 E36M3 which incorporate dust/water seals. Of the two I was considering install just the monoballs on the TS from Turner since they sell them separately and I have a press. I did the replacements on the M3 so I have a bit of experience refreshing that suspension as well. Jvac, Thanks for the thread pointer. |
07-15-2019, 04:45 PM | #166 | |
¯\_(ツ)_/¯
945
Rep 1,762
07-15-2019, 08:27 PM | #167 | |
Rep 785
Thanks for your service. Please get home safe and sound.
07-17-2019, 12:45 AM | #168 | |
Rep 2,499
I'm also running a 2014 335i with the M Performance suspension and I want some more steering feel in the front and it sounds like the best two options would be either 1) M3 LCA + M3 Thrust Arms or 2) Monoball Thrust Arm bushings. Doing both seems like overkill since I want to keep some road manners. Do you have any specific thoughts on that? Thanks. |
07-17-2019, 12:21 PM | #169 | |
Rep 3,947
DVC went through this progression and believed that the monoball bushings would not be great for a DD. |
upsidedownfunnel1996.00 |
07-17-2019, 12:27 PM | #170 | |
Car Hypochondriac
335
Rep 901
I've been on the edge of buying a set, but that's my biggest concern. What is needed to fit M3 thrust arms on the f3x? I understand the bushing itself is thinner, so you need spacers, right? Is there info on what to use as spacers? Last edited by Eschmacher; 07-17-2019 at 12:46 PM.. |
07-17-2019, 12:32 PM | #171 | |
Rep 3,947
07-17-2019, 12:48 PM | #172 | |
Car Hypochondriac
335
Rep 901
So will I run into geometry issues if i go with m3 TS and kmac camber bushings rather than the m3 lca? Trying to avoid significant changes in caster. Trying to improve the thrust arm bushing, and add camber without ruining it as a DD. |
07-17-2019, 01:57 PM | #173 | |
Rep 2,499
07-17-2019, 02:09 PM | #174 | |
Rep 3,947
So one issue that may have resulted in fitment issues was using the BMW camber correction hubs. Camber plates will move the entire suspension assembly. However, a camber correct hub will not, it will just tilt the wheel inwards. Which means it will reduce your sidewall to strut clearance. I was lucky I went with 255 width tires because 265 width tires would not have cleared the strut. I probably would have needed a greater offset if I went with a wider tire. |
07-17-2019, 02:57 PM | #175 | |
Car Hypochondriac
335
Rep 901
07-17-2019, 03:47 PM | #176 |
Rep 3,947
It'll move the wheel forward in the wheel well. I only have very slight rubbing against the wheel inner if I'm fully compressed and turning near end of lock. Otherwise, no issue.
