04-29-2019, 10:15 AM | #1 |
Rep 122
5mm spacers, extended bolts?
I've gotten mixed results while searching for this, but I'm debating a 5mm hubcentric spacer in the rear for my square 19x8.5 +35 setup to get the rear to match the flushness on the front. Would that require extended bolts as well?
05-05-2019, 04:30 PM | #2 |
BMW CCA Member
488
Rep 808
Ok so from my BRZ experience, a 3mm spacer is the most you can run with stock bolts and still have enough bite. At 5mm... that's one more thread length.
If the BRZ people are worried about 2mm with only 200hp... I'd lean toward more threads on a 300hp+ car. If I were you, since you are already dropping coin on rims and tires, I'd get the longer bolts. |
rphz70.00 |
05-07-2019, 12:54 AM | #3 |
David
786
Rep 2,009
Most kits come with bolts, and yes, I would highly recommend bolts at 5mm
"BRZ people" have studs and lug nuts, not lug bolts, but in the end it's about thread engagement, not power output. 4-5 full turns is what I personally would consider safe. |
05-07-2019, 09:10 AM | #4 |
Rep 99
I’ve read where some folks say that 5mm is too thin a spacer and that minimum thickness should be 10mm or 12mm because of hub engagement.
I never really thought about spacers until just recently and it seems like there are a lot of differing opinions out there. Specifically, what is the minimum thickness to be considered safe front and rear? I’d like to make a subtle difference in the look/stance of my car and that’s why I’m more interested in knowing what the minimum safe requirement is. Thanks! |
05-07-2019, 09:59 AM | #5 |
Rep 122
I had a couple people message me and tell me they run 5mm without an issue, so I installed them as is. I actually got a little over 7 turns on mine. I think it is okay to run them without extended bolts.
05-07-2019, 10:01 AM | #6 | |
Rep 122
05-07-2019, 01:41 PM | #9 | |
David
786
Rep 2,009
05-17-2019, 01:19 PM | #10 | |
Rep 8,495
BMW hubs and OEM/compliant wheels are machined as hub centric for a reason. They also make wheel fitting much easier. Flat spacers can compromise the hub centric alignment, leading to rotational imbalance.
05-17-2019, 10:22 PM | #11 |
Not stock
474
Rep 614
There's actually a standard on thread engagement - look up M14 thread engagement
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
05-19-2019, 09:26 PM | #12 |
Rep 122
05-20-2019, 12:54 PM | #13 |
Rep 10,256
I would suggest to explore ...
https://machtschnell.com/catalog/pro...l-accessories/ ... as safety doesn't have price. At $150 MSRP (and less), peace of mind could not be purchased at a more reasonable amount. |
05-21-2019, 07:24 PM | #14 |
Rep 99
Is there a minimum hub-centric thickness depending on front or rear? I’ve read where some say 12 mm min on front and 10 mm rear but I couldn’t understand why there would be a difference.
05-25-2019, 02:42 PM | #15 |
Rep 8,495
I think the minimums are 10mm front and 12mm rear. The hub centric protrusion differs F/R.
05-27-2019, 08:49 PM | #17 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Most wheels will still contact the hub with a 5mm spacer. 3mm is always usable
I would get studs or extended lugs with any spacer
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
05-27-2019, 08:50 PM | #18 |
Rep 16,079
For those of you unfamiliar with the metric system 5mm is just shy of 1/4 inch. The nominal track width of an F30 is 1550mm front, 1580mm rear. Adding a total of 10mm to the track width isn't worth the bother or expense.
05-27-2019, 08:52 PM | #19 | |
Rep 6,734
Future Classic spacers are the best I've seen. Prior to their release Turner Motorsports spacers were my goto option.
'23 X7
05-27-2019, 08:54 PM | #20 |
Rep 6,734
There are other reasons for spacers. One example is for front strut clearance with aftermarket wheels. Aesthetic benefit can be a motivation as well.
'23 X7
05-27-2019, 09:51 PM | #21 |
Rep 99
05-28-2019, 07:51 AM | #22 |
Rep 122
Yeah, I got them for the rear since I’m running a square setup on my xdrive. 5mm was perfect to make the rear match the fronts.
