05-10-2019, 11:21 AM | #1 |
Rep 15
Thoughts on 18s vs. 19s for a daily set up?
I am trying to determine whether or not 18s or 19s would be a better set up for my daily driver. I live in LA so there is going to be a lot of messed up streets and people who don't know how to drive properly. My cousin (who knows a lot about cars, especially BMWs) advises that 18s would be better for me, but from what I know 18s are hard to come by in both wheels and tires.
I have never done a wheel set up before so the measurements are foreign to me and I'm not sure if I should do staggered/non staggered. I am basically starting from scratch. |
05-10-2019, 12:09 PM | #2 |
Rep 4,329
comparing tires of the same size and diameter of the same brand and model, 18" tires will have 0.5" more sidewall, so it'll have a better ride and impact protection. 18" wheels/tires cost less than 19" which arguably look better.
what kind of budget for both wheels/tires do you have? summer tires or all seasons? will you be lowering your car? |
05-10-2019, 04:07 PM | #3 | |
Rep 15
I'm really not sure what the difference is between summer and all season tires or which ones would be better for daily driving through LA. I wanted to lower it a bit, but not sure how much I should go. |
05-10-2019, 06:11 PM | #4 | |
Rep 4,329
if you want staggered. 18x8.5" +(30-35), 18x9.5" +(40-45) on 235/45/18+265/40/18 or 245/40/18+255/40/18. for square 18x8.5" or 9", with 235/45/18, 245/40/18, or 255/40/18. what kind of wheel face do you like. 5 6 7 8 9 10 12 single spokes, twin spokes, Y-spokes, U spokes, mesh? |
05-10-2019, 08:45 PM | #5 | |
Rep 3,748
You don't worry about wheels with bad driver, that's more like dings and scratches on the body of the car. And your last statement about tires availability for 18", there are plenty. As of now 17" are the standard on most cars and many are growing to 18" so no worries on tires unless you run 15" to 16" which too small for BMW. |
05-12-2019, 04:13 PM | #6 |
Rep 8,942
If $2k is your budget Apex on a group buy along with tires and sensors mounted and balanced should get you about there. Enkei makes nice wheels. BBS SR or SX also a decent value option. Stick with 18" bigger is about show, not go.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
Machinebuilder278.50 |
05-13-2019, 03:32 PM | #7 | |
Rep 15
Is there a reason to go staggered? Or is it just for looks? I was looking into HRE FF04, but when I inquired I found out they don't make them in 18s. |
05-13-2019, 07:23 PM | #8 | |
Rep 4,329
for 18" rotary forged wheels that are somewhat similar looking to the HRE FF04, i suggest the Beyern Ritz 18x8.5 +35 square or for staggered, 18x8.5 +35, 18x9.5 +45. wheels+tires wiill be right around $2K depending on your tire sizes and choice. here is an M3 with 18" i believe. the rear wheels i recommended will not be as aggressive. comes in black or machined with black inserts. another wheel to consider is TSW Bathurst. can do square or staggered fitments as well. 8.5 +35 has mild concave and comes in silver or gloss gunmetal. FYI, TSW makes Beyern wheels. Added Stance SF03, rotary forged, custom offset, silver, black or gloss black/tinted machined. couldn't find an F3/4 pic. Last edited by alohasurftoad; 05-14-2019 at 09:01 AM.. |
05-14-2019, 11:41 AM | #9 | |
Rep 15
alohasurftoad3078.00 |
05-14-2019, 12:35 PM | #10 |
Rep 2,805
Drives: F33 430 and F39 M35i
Let us know what you decide. With our crappy roads, I probably should’ve stuck with 18s but I went 19s because I like the way it looks.
05-21-2019, 03:47 PM | #11 | ||
Rep 1,805
The difference between a 19 and 20 is negligible. Just pay attention when you drive.. And I have a set for sale... right in your price range
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
05-21-2019, 06:49 PM | #12 | |||
Rep 8,942
2022 Macan S
05-21-2019, 08:14 PM | #13 |
BMW Convert
108
Rep 201
Generally asphalted roads ride much better and softer than concrete roads, but unfortunately 90% of the freeways i drive are concrete. And all the relief cuts made in the concrete to prevent cracking makes for a horrible ride with low profile tires in my opinion. I upsized on my E Class diesel and regretted it.
But as others mention, they do not mind the ride so i guess it just all depends on where you live and your commute. I drive about 70 miles to work and back on horrible Los Angeles freeways so i went with 18s. I also upsized the tires so i have more rubber than the factory 18s. However, if you don't lower the car, the 18s will look small. |
