12-28-2019, 01:11 AM | #2641 |
Rep 2,964
I'm in HB too! If you ever have a need keep in mind we have two e85 stations on beach blvd - so it's relatively convenient. I run an E30 blend with my MP tune and 340.
12-30-2019, 01:12 AM | #2643 |
Rep 500
Drives: BMW 330e F30 M-sport
Yes, AFR will go all over the place when you're not applying pressure to the accelerator.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
01-01-2020, 07:48 PM | #2645 |
Rep 77
Heres the whole log. Looks like the throttle angle is controlling the boost pressure which doesn't make much sense to me.
https://datazap.me/u/alexp930/log-15...=1-3-4-6-20-31 |
01-01-2020, 08:05 PM | #2646 |
1288
Rep 3,502
Hard to view on my phone but what does the map psi say, thats what id want to know.
01-01-2020, 08:24 PM | #2647 |
Rep 77
01-02-2020, 02:35 PM | #2648 | |
Rep 7,555
Overall that is "normal" behavior, but if you are overshooting boost every single time you do a pull and consistently getting throttle closures that might be cause for concern. Do a few more 4th gear logs (preferable only the pull in the log so we don't have to trim it) and confirm. |
ronanz1818.00 |
01-02-2020, 02:40 PM | #2649 | |
Rep 77
Okay thanks for the explanation. I was just worried I would harm the car, but also not very experienced on the platform at the moment. I'll try and get a cleaner log tonight in just 4th gear. I was also going to flash back to stock and try to run back to back logs. Thanks |
01-02-2020, 06:23 PM | #2650 |
Rep 77
Okay I managed to get some good logs. These seem to look way better. I noticed a couple knocks detected through a couple of the runs, is this enough for concern? I can always tune for 91 and run 93.
OR am I completely over analyzing this data and should just drive the damn thing Thanks https://datazap.me/u/alexp930/stage-...12-19-21-27-31 https://datazap.me/u/alexp930/stage-...12-19-21-27-31 https://datazap.me/u/alexp930/stage-...12-19-21-27-31 Last edited by plantman77; 01-02-2020 at 07:16 PM.. |
01-02-2020, 06:58 PM | #2651 | |
Rep 7,555
Is your car completely stock besides the tune? IAT climbs quite a bit during the pull so i am guessing stock IC. |
01-02-2020, 09:23 PM | #2652 |
Rep 77
Yeah I figured knocks during WOT are not good. Not looking to blow the car up.. So I just quick flashed the 91 tune and I'll try to get some logs going to work tomorrow. I'm in the Northeast so gas quality should be pretty good for 93, but I've been getting gas at BJ's and Wawa.
Car is stock with the exception of a charge pipe. Also have a catted DP on order and plan on doing the IC shortly after to go Stage 2. |
01-02-2020, 09:42 PM | #2653 |
Rep 691
Why is the target boost in 6th gear on 91ACN so low (half of 5th gear)? It feels like hitting a wall when shifting from 5th to 6th. I understand that 3rd and 6th are the weakest in the ZF 8spd trans but there isn’t a reduction on 3rd gear boost.
01-03-2020, 07:31 AM | #2654 |
Rep 1,499
Updated maps released..
Stage 2 93 octane V6.4: 26% HP / 38% TQ Stage 2 93 octane V7.0: 29% HP / 48% TQ Stage 2 E30 octane V6.4: 29% HP / 44% TQ Stage 2 E30 octane V7.0: 33% HP / 56% TQ Version 7.0, January 03, 2020: - Boost target changes - Boost and load control - Power increase I'm about to flash but won't be able to take it for a spin until lunchtime. Hopefully, the rain holds off
01-03-2020, 04:11 PM | #2655 |
Rep 77
Short pull in 6th on 91 Stage 1 map. Still got a knock. Also looks like its pulling timing in cylinder 4 and 5. Flashing back to stock and going to check for knock on those logs. I doubt the gas in the tank is that bad.
https://datazap.me/u/alexp930/stage-...a=4-6-19-20-27 |
01-04-2020, 08:38 AM | #2657 |
Rep 1
Burble Tune Not showing "Sport +"
I recently purchased BM3 and when I was looking at the custom burble tune option for my car it doesn't have Sport + it only has Sport, ive seen videos and posts of others having custom for sport +. Any advice on what I should do?
01-04-2020, 09:05 AM | #2658 | |
Rep 1,105
ronanz1818.00 |
01-04-2020, 10:22 AM | #2659 | |
Rep 931
01-04-2020, 08:09 PM | #2660 |
Rep 14
So I just flashed the newest update to my car (335i EWG). I took a log of a 3rd gear pull, but noticed my boost drops to under 15psi at about 4500rpm and never comes back up. Is this normal for the stock turbo?
My car is stock other than a BMS intake and a FTP inlet pipe. Full Log Last edited by Myst420; 01-04-2020 at 08:22 PM.. |
