BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Driveshaft upgrade
      04-15-2023, 08:32 AM   #1
B58togo
Drives: M240i
Driveshaft upgrade
So I have an appointment to get the Pure 800 cast, DS2 and new injectors installed 4/27. I plan on having Doug Newton tune it on E40-E50. I'm also going to pick up a pair of Welds and 275/40R17 MT ET Streets to go to the track with. Is anyone running this driveshaft? Has there been an increase in shaft failure in the 600+ WHP range? I already have the JXB upgraded carrier bearing.
https://mrmperformance.com/products/...40240953622637
https://www.jxbperformance.com/produ...arrier-upgrade
      04-15-2023, 05:39 PM   #2
blacksapphire440i
Novice
blacksapphire440i's Avatar
322
Drives: 2018 440i Gran Coupe
Currently running stock driveshaft tuned by Doug Newton as well on DAW v2.5+ and DS2. I would recommend going with the driveshaftpro upgrade as that will be my next upgrade and I have not heard of anyone blowing up their driveshaft @ the 600whp-650whp range.
B58togo820.00
      04-16-2023, 05:19 PM   #3
5w20
@_sunbish
5w20's Avatar
314
Drives: Bmw 435i & 340i
It’s not the hp that breaks the driveshaft, it’s the force of the Tq applied when you get good/great traction or if you wheel hop. It’s dig racing that breaks them, roll racing is highly unlikely to break it. The force applied isn’t nearly the same.
I broke the stock driveshaft when I was on Hoosier drag radials and stock turbo at the track. I got the DSP driveshaft from MRM as well, takes about a week from order to delivery. Unfortunately I haven’t been back to the track, but the few times I’ve launched it on the street to do a dragy run, I’ve managed to cut a few 1.7 60’s without issue.
Tbh if I was to do it over, I would go custom. There’s nothing wrong with the DSP driveshaft, I would go about it a different way as personal preference.
As far tires, I’d highly suggest getting the M/T ET street R’s over the SS’s. Since you’re going with a upgraded turbo, you may want to look at getting the 305/45 size if you’re stock height and do the minor modifications needed to make them work. I’m currently on the 275/40 size, but going with a similar setup as you and I’m more than likely going with the larger tire.
If you’re in Texas, I may consider getting rid of my current setup for the right price.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5
B58togo820.00
      04-17-2023, 04:50 PM   #4
B58togo
Drives: M240i
I would love to go with 305s, but I’m an F22, so that isn’t happening!
      04-17-2023, 05:38 PM   #5
robsciam
Drives: 440i
b58togo may i ask whos doing turbo install? iam also in new york looking for a shop to do mine
      04-18-2023, 02:45 AM   #6
blacksapphire440i
Novice
322
Usually what comes with that power range of 600-650whp in B58 powered cars is 600-650wtq sorry for the confusion
      04-18-2023, 08:50 AM   #7
B58togo
Drives: M240i
Senshine Motors, between Utica and Rome. I could do it myself, but just don’t have the time. My guy that did the VTT GC, a couple years ago is MIA.
BTW, if anyone’s interested in a GC with ~7-8k miles and a Dorch Stage 1, they’ll be on the classifieds.
      04-19-2023, 06:02 PM   #8
5w20
@_sunbish
5w20's Avatar
314
Again, I highly doubt anyone will ever break the driveshaft at when making pulls from a roll. I haven’t seen anyone do so and if they have it’s been very few, but I could be wrong.
      04-19-2023, 06:07 PM   #9
5w20
@_sunbish
5w20's Avatar
314
If that’s the case, accept no substitutes and definitely go with M/T ET street R tires if you can’t go bigger than the 275/40.
How much smaller are the 2 series in the rear wheel wells? The 305/45 combo isn’t direct fit for a 3/4 series either, but it does take minor modifications to make it work.
      04-20-2023, 07:13 AM   #10
pauli18c
pauli18c's Avatar
Drives: 2017 340i RWD M Sport
Do you just not like the GC, or why are you ditching it so soon?
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup
      04-20-2023, 04:19 PM   #11
blacksapphire440i
Novice
322
You are right I have definitely seen some people twist their driveshaft on a roll race (if the car is consistently used for 60-130s, roll races, etc) but it is not often if you conservatively drive at times. I would definitely upgrade to the Driveshaftpro as I have not seen any failures in the 600-700whp/wtq range
      04-21-2023, 12:21 AM   #12
JBH6612
Drives: 2017 430i coupe M package 6 sp
2017 BMW 430i  [0.00]
Bro contact driveshaftpro directly and it might be cheaper. They’re in California and you can Google them. Based in garden grove.
      04-23-2023, 08:12 AM   #13
B58togo
Drives: M240i
It's gonna be tight with the 275's. I currently have 265 Michelin PS4S and they run a bit wide. I may need to run a bit more negative camber. I don't think anyone has gotten wider than 275 on a 2 Series.
Really wanted the Pure 800 back in 2021, but it was a two month back order, so went with VTT. Once the slightly bigger cast version dropped, decided to do it and the DS2. Doug Newton has a cast Pure 800/DS2 Gen 1 340i, running 60-130 in 6.70 seconds, which is almost a full second quicker than my current setup. Hoping to run 10.40's in the quarter. It's tough with RWD.
      11-02-2024, 04:17 PM   #14
Not A M4
Not A M4's Avatar
Drives: BMW 440i xDrive Stage 3
Hello, I twisted mine like a twizzler at 650ish whp with a similar set up on an xDrive 440i.
      11-02-2024, 06:38 PM   #15
blacksapphire440i
Novice
322
I switched to a big turbo PTE 6470 now so I doubt ill have my driveshaft turn into a twizzler going into rolls
I never do digs.
sorry to hear that you broke your driveshaft
      12-06-2024, 05:01 PM   #16
F36_Chris
F36_Chris's Avatar
Drives: BMW F36 440i
I ended up breaking my driveshaft at the base near my rear diff I'm only stage 2 dp, front mount intake and tune, going with a Driveshaft Pro and I would not recommend getting it from MRM they don't ship out orders and charge your card no communication at all either I had to file fraud to get my money back.
