12-13-2022, 03:22 PM | #221 | |
sergeant
66
Rep 99
Drives: BMW F30 328 xDrive Nimble
I always thought that it is better to change the sway bars in pair, e.g. that the kit is a better solution to avoid any safety risks that different sway bars may arrise. I guess i was wrong. |
12-13-2022, 05:34 PM | #222 |
Rep 5,392
I used to advocate changing sway bars in kits from the same manufacturer because the assumption was that they actually did a lot of testing with different sized front and rear bars to determine the best front/rear match for the chassis. But I don’t think that that is necessarily the case now. From my research the shared information indicates that it’s better to choose from the best front and rear sway bars for the car application.
karapet8566.00 |
12-14-2022, 05:55 AM | #223 |
sergeant
66
Rep 99
johnung
Thank you. Real usage feedback is very important to me. You also covered the theoretical part. I used to think that hollow bars are good ( I bet many others too ). At this point, I will wait for my EPK and decide what to do next. H&R for the front and KC for the rear is my favorite for now, but I will do more research before taking any actions. It is a bit strange that KC is not manufacturing/selling the fronts too. Another company selling a sway bar kit is Dinan, but their sway bars are hollow too. |
12-14-2022, 06:29 AM | #224 | |
Rep 5,392
Race teams have engineers who can use hollow bars to cut weight while making sure that tubing thickness and shape is strong and safe for the track. On the consumer side it’s too little engineering, mostly cost cutting and a bunch of slick marketing to gloss things up. Once I started seeing photos of snapped hollow bars I realized that there’s a reason that a company like H&R still makes and sells solid steel bars. I’ve been using there sway bars for many decades. Old VW GTI’s had easy sway bar access so it was really simple to play around suspension tweaking by swapping in a smaller/larger front or rear sway. Track guys would do it to setup their car for specific tracks. The H&R solid bars were so consistently well made, reliable and safe. Great German engineering. KC Design actually used to have a 28mm solid front bar for a RWD model. I don’t see it in their catalog now. Once I saw the KC sways next to the H&R sway bars. They were very similar, almost identical. That’s why I have complete confidence swapping out my 20mm rear H&R bar for a 17mm KC model. In my previous conversations with KC, they said that they do their product development by bringing in a car for their engineers to work from. Well it turns out that BMW doesn’t sell XDrive cars in Taiwan. I’m guessing that might be the case for most of Asia. So that’s why they never made XDrive front sway bars. |
karapet8566.00 |
12-27-2022, 10:46 PM | #226 | |
Rep 1,369
My route to learning about bump stops on on ACS springs + Koni Yellow Sport Dampers. Car is 2017 340 xDrive OE bumpstops = crashy over any bump bigger than a pebble F80 (front and rear) bumpstops = better but still crashy over medium or larger bumps Dinan (front) + F80 (rear) bumpstops = a lot better. You've got to hunt for a bump and hit it hard to ride those bump stops. Why the F80 bump stops in the rear and not the Dinan? The hole in which the damper piston rod runs through is too narrow on the Dinan bump stop to accommodate the Koni Yellow damper piston. Plus, the Dinan rear bump stops are too short to protect the piston. The F80 was a better match.
12-27-2022, 11:17 PM | #227 | |
Rep 1,369
CRITICAL: I couldn't find any setting with the Koni Sport dampers that would eliminate crashiness over ever average sized bumps when using RUN-FLAT tires. Highly suggest use of NON-RFT tires I have the Koni Sport (i.e. yellow) dampers paired with ACS springs (which are friggn' fantastic by the way). This is what I have learned over the last year of using them. For the rear, 2/3 from full soft (i.e. fastest reaction setting) For the STREET, for the front, 3/4 from full soft. This WILL introduce some bounciness but is a better choice than teeth smashing hell on higher settings For the TRACK, for the front, 1 1/2 turns from full soft. Roll is minimal. If you have the time, set the rear to 1 full turn from full soft. Dislikes: Wish I could keep the softer settings without the bounciness. Likes: I have the flexibility to change the settings. For an adjustable damper, the Koni Sport is decently priced. Tip: You can read every internet post out there but trying the settings yourself are going to be the best teacher.
02-22-2023, 08:45 AM | #228 |
Rep 481
First of all thanks SOO much to the many members who have provided invaluable information on this thread so far. I've gone down a huge suspension rabbit hole researching how to responsibly give my car a modest drop, found this thread. How this relates to ARBs? Well, I was looking at the M Performance Suspension Kit (33502320981 pre LCI 335i kit) which indicates that its only compatible with cars that have the M Sport Suspension. Looking at the table of chassis and bar thickness, I don't understand why the M sport suspension is necessary to put the M Performance Suspension on a 335i (pre LCI)? From what I can see, the M sport front is 1 mm thicker in the middle, but equivalent on the ends (25/22.2 vs 25/21.2). The rear is 1mm thicker. Can someone explain why the M performance Suspension would be incompatible with stock 335i ARBs? Furthermore, would the M Performance Suspension work with different aftermarket ARBs and/or the recommended 15 mm m2xx rear bar? |
02-22-2023, 01:02 PM | #229 |
Rep 383
It’s not strictly speaking incompatible.
Just that the package was intended for use with the bigger bar. Nothing is stopping you from running it as is, or from using aftermarket bars (in fact from a performance perspective an aftermarket bar would be better if you are going to go through the trouble of swapping, IMO). You’ll have a bit more body roll, and the car will feel a bit softer during cornering without it. Plenty of people have put on stiffer suspensions without changing roll bars. It may not be optimal, but it’s still serviceable. If you can’t afford it now, I can be done down the line if you feel you need it. |
rlesko232.50 |
02-22-2023, 01:16 PM | #230 | |
Rep 481
02-22-2023, 03:57 PM | #231 | |
Rep 5,392
Are you still updating this sway bar list? (It’s very helpful) Or is someone else? I have some corrections and additions and want to send them to the correct person. Thanks! John |
02-23-2023, 02:23 AM | #232 | |
Rep 8,498
If you PM him he may be able to send the table to you.
Last edited by Watsey; 02-24-2023 at 11:22 AM.. Reason: Typos - I hate iOS auto text correction. |
johnung4528.00 |
02-23-2023, 02:51 PM | #233 |
Rep 481
02-24-2023, 06:13 AM | #234 |
Rep 5,392
02-24-2023, 06:18 AM | #235 | |
Rep 5,392
CAN SOMEONE PLEASE FORWARD THIS REQUEST TO THE ADMINS OF BIMMERPOST TO SEE IF THEY CAN ASSIST? THANKS! JohnU |
02-26-2023, 07:19 PM | #236 | |
Rep 99
I'm running an H&R front sway bar with a 15mm BMW rear bar. H&R rear is quite stiff for a road car its not that it is wrong... Johnung helped me out a lot when I was considering the upgrade and did Frakle. |
02-26-2023, 07:26 PM | #237 |
Car Hypochondriac
335
Rep 901
Alright, so I've gone through this entire thread and I'm still not sure what to do...
My subframe is going to get dropped soon, so I figured I would explore upgrading the front bar. At the moment, I do not plan on upgrading the rear. Which bar would be the smallest step up in terms of stiffness from the 335 M-sport bar? (25/22.2). Currently have Eibach prokit springs and B6 EDC dampers. I get quite a bit of body roll and understeer during auto-X. Can see this in my profile pic. I plan on installing millway street camber plates as well, so that should give me a lot more grip up front. Obviously a stiffer front bar would usually mean more understeer, especially without a rear bar that's been tuned correctly. Perhaps the best option would be to just be to forget about it and leave it stock?
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
johnung4528.00 |
02-27-2023, 01:32 AM | #238 | |
Rep 5,392
The stock front sway bar is undersized, which is why the F3x has so much body roll. Heavier and heavier front springs just destroy the ride. It’s just not the way to properly control body roll. The only configuration where I have heard that it might be best to leave the stock front sway bar is with the ridiculously heavy front springs on the Bilstein B16 coilover kit. I have Eibach springs on my car. The spring rates are a little higher than stock for control without a harsh ride. They really benefit from the H&R 28mm front sway bar. It’s a night and day difference. The car went from excess body roll to cornering flat! I understand your concern that you could install a thicker front bar and increase understeer. Honestly it didn’t feel that way. Remember all those different forces at play. I think that the 28mm front bar adds so much control by reducing body roll that if understeer increases, it’s not as noticeable. The front sway bar is a bear to swap out. If you are going to have your subframe dropped I highly recommend doing the H&R front 28mm sway bar at the same time. Note: H&R makes four slightly different 28mm front bars for the F3x depending on engine and RWD/XDrive. See photo. You didn’t say which rear sway bar is stock on your car. I’m guessing 12mm-15mm. Realoem can tell you right away. Swapping the rear bar is a piece of cake compared to the front. A buddy of mine who has done them said 3-4 hours. I’m refreshing all of my rear spring/shock rubber bits at the same time. FaRKle did a nice video below. https://youtu.be/GBrMeaTSpqs After you get your front end back together, I suggest driving it and getting a real feel for how it handles with the upgraded front sway bar. Then if you decide to go with a thicker rear bar, you have options: 14mm, 15mm, 16mm, 17mm, (might be a 19mm). It would actually be pretty simple to choose. I’ve already discussed why the H&R 20mm rear bar is a little too heavy. And if you decide to install a thicker rear sway bar you aren’t going to increase by 1mm. You’re going to increase by at least 2mm-3mm. So that really narrows it down. Hope this helps! |
Eschmacher334.50 |
02-27-2023, 03:48 AM | #239 | |
Rep 8,498
From my own personal experience of a) OEM Sport springs + EDC, b) ACS springs + EDC + poly bushes, c) Ohlins R&T + H&R anti-roll bars + Millway camber plates + poly bushes, d) Onlins R&T + Eibach anti-roll bars + Millway camber plates + poly bushes + monoball bushes, I can assure you that I found the H&R bars too stiff for all-round road use and that I far prefer the Eibach units (especially the rear). Suspension needs a degree of compliance to allow the car to 'flow'. I could lean harder on the H&R bars but snap oversteer was a problem. My track corner speeds were not affected using the Eibach units and the car was more predictable. Suspension is, of course, a combination of multiple components => springs, dampers, ARBs, bushes, tyres, geometry, to name a few. It's also very subjective in terms of what the driver wants to achieve. Getting it right can empty wallets.
02-27-2023, 06:10 AM | #240 | |
Rep 5,392
Both sway bar kits that you mentioned use 28mm front sway bars: H&R uses a solid bar and Eibach a hollow bar. I’ve already mentioned my disdain for hollow bars because they are known to snap and my friend died when a front suspension piece snapped on his car. The H&R solid rear 20mm bar in their kit is too heavy, which causes more oversteer and wheel lift that reduces the size of the tire patch/grip. The Eibach solid rear 16mm bar gives the car more balance. (My stock rear bar was the BMW 12mm) The BMW solid rear 15mm and KC Design solid rear 17mm are two other good rear sway bar options. ACS and Eibach are typically the same spring & spring rate. The Ohlins springs are probably higher spring rates which could make the H&R sway kit feel exactly how you described. With my Eibach springs, the H&R front sway bar feels perfect. It’s the H&R rear 20mm bar from their kit that feels too heavy. That’s why I’m swapping it for the KC Design 17mm rear sway bar. I could use the Eibach rear 16mm bar but it’s difficult to purchase outside their kit in the US. Very easy to obtain separately in Europe. Eibach part number is in the attached photo. |
02-27-2023, 10:45 AM | #241 | |
Car Hypochondriac
335
Rep 901
My previous car was a GTI that had full suspension, sway bars, adjustable endlinks, etc. and I was very regretful in how much it all took away from the daily driveability. I've been trying to avoid repeating that on this car lol.
02-27-2023, 11:07 AM | #242 | |
Rep 99
The thinner rear (than H&R) was a reccomendation by Farkle. Having a little more movement in the rear isnt a bad thing at all it keeps ur tires in contact with the road. Consider this if you drive in winter comditions, you will loose traction quicker with a stiffer set up. I know this from driving in a lot of snow. and ice. As a side note I also have frieds who race cars and if it's very wet they sometimes disconnect the sway bars. Admitantly these are formula Ford's but the reasoning makes sense. Keep the tires in contact with the surface. Final thought.... I installed the rear 15mm bar first and the back end wanted to let loose a lot which is a really strange feeling in an X-drive. It didnt feel safe so balance is key. Good luck its all a learning process... |
johnung4528.00 Eschmacher334.50 |
