01-06-2024, 04:12 PM | #1 |
Rep 115
Inspection pre warranty expiration F30 B46
2017 330iX B46 SULEV with 64,000KM (40,000 miles)
Extended warranty will expire in a little over two weeks and wanted to gather input about specifics to inspect. The dealer has already received approval from corporate to replace the front engine mounts. I knew about the issue last year but at the time the dealer simply offered a firmware update. Happily accepted as I knew I’d have more time to properly diagnose. The dealer did note during the recent inspection some oil drops on the underbody cover but didn’t specifically go hunting. My independent specialist has me dropping off the vehicle on Monday and already mentioned he’ll be checking the oil filter housing gasket as well as the water pump. Otherwise the cylinder head ventilation line was replaced by the dealer. The independent specialist will check thoroughly but any specifics come to kind based on recent experiences shared on the forum? Did my best to search as well. Your input and thoughts are greatly appreciated. Thank you. |
