      06-22-2013, 08:48 AM   #3873
shawnsheridan
shawnsheridan's Avatar
Originally Posted by 328fresh View Post
From what I understand, the wiring is in the car already. I know I will need the comfort access door handles. What I am not sure about is the combox, keyfob, and coding. That's where I'm looking for assistance.
Even if the wiring is there, I don't think the Receiver Antennas are there, I think you also need a new CAS Module, and maybe the Passive Go Module.
This is beyond my capabilities.
      06-22-2013, 08:59 AM   #3874
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Originally Posted by avgor123 View Post
Hi all!
I have retrofitted my F30 CD-Radio with used NBT. I have not TCB.
I add 609, 6NK, 6NR and 620 options to VO and VO coded the HU_NBT.
1. The Navigation tab is not active. Have I to buy FSC code or CAN-filter to activate Navigation?
2. Does voice command 620 require FSC code too?
3. There is not Internet tab in menu. How can I get it?
4. My HTC HD2 phone connecting to NBT via BT as handsfree and audio streaming but not as internet modem. And there is not globe icon near my HTC phone in BT menu.
Help, please.
Can you tell me more about how you did this? Other than the head unit, what did you need? Did you originally have 606 instead of 609?
If you could also tell me if you need any adapters for the wiring, it would be much appreciated. Was your car built before 07/2012?
I'm currently trying to see if it is possible to retrofit NBT by just replacing the head unit on a CIC equipped car.
      06-22-2013, 12:39 PM   #3875
tasuzuki
Drives: F01-740i
I'm driving a 2009 BMW F01 EU 740i.
Could someone please send me a mail how to obtain E-Sys 3.18.4 and PSdZData 48.3?
      06-22-2013, 12:42 PM   #3876
shawnsheridan
Not with only 1 post. Either increase your Post count until you can receive PM's, or post an email address.
      06-22-2013, 01:49 PM   #3877
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
My 320d sport was built at 05/12. It has no 606 originally, only Radio Professional.
I bought the used NBT (HU+CID+iDrive joystick+ GPS antenna).
Additionaly I bought 2 microphones, 1 HUH-USB cable, AUX/USB connector.
I changed the pinning at existing HU-CID cable instead of buying a new cable HUH-CID.
I made 2 identical antennas of SMD connector, RG174 cable and WiFi stick antenna from any WiFi router. One for BT,one for WiFi.
I found few bushing connectors and some cable to connect 2 microphones to HU. All installation procedures take about couple hours.
Then I added 609, 6NK, 6NR, 614, 615, 616, 620 options to VO and VO coded the car with zeitkriterium 0712.
      06-22-2013, 08:10 PM   #3878
tasuzuki
Drives: F01-740i
Please send an email to jptk8190@yahoo.com
      06-22-2013, 08:20 PM   #3879
shawnsheridan
Email sent.
      06-22-2013, 08:45 PM   #3880
tasuzuki
Drives: F01-740i
Email sent.
I'm asking E-Sys 3.18.4 and PSdZData 48.3.
Could you send an email to obtain those version ?
      06-22-2013, 08:49 PM   #3881
shawnsheridan
Email sent.
      06-22-2013, 10:23 PM   #3882
Bricheun
Drives: F30 328
I noticed that the cheat sheet "F30_Cheat_Sheet_20120616" is for 2012 models, I have a 2013 March build - is the method just the same as the 2012?
      06-22-2013, 10:29 PM   #3883
shawnsheridan
Yes.
      06-23-2013, 12:19 PM   #3884
Bricheun
Drives: F30 328
Thanks Shawn for helping me out -- finally done my first coding :-)
Now the big problem is the M Performance brakes coding...any help or advice on what to do after adding the SPBR in the HO-WORT?
Do I need to code the DSC ? The garage told me it's not necessary and it will "adapt" by itself, I don't believe that from what I have read it is necessary to code to get the full benefits.
It is exciting and scary the first time coding , really afraid of screwing something up.
      06-23-2013, 12:25 PM   #3885
shawnsheridan
Right-Click on SVT where VIN is showing, and select CODE to VO Code entire SVT. Since DME will be part of it, the Motor cannot be running.
      06-23-2013, 12:50 PM   #3886
Bricheun
Drives: F30 328
Great Shawn...you are the best...
      06-23-2013, 12:52 PM   #3887
shawnsheridan
FYI. This will wipe out any custom FDL Coding, so you would need to go back after VO Coding SVT and redo any FDL Coding.
      06-23-2013, 09:24 PM   #3888
Bricheun
Drives: F30 328
I assume this is done in the VCM module under VCM Master top right windows box.
      06-23-2013, 09:34 PM   #3889
shawnsheridan
No. It is done in the standard Expert Mode => Coding module, where all other FDL and VO Coding is done.
      06-23-2013, 09:37 PM   #3890
Bricheun
Drives: F30 328
Thanks again - sorry it's early here and my head is not fresh, I saw it as you mentioned. Reverting back to default is fine - I can code again fresh.
      06-24-2013, 05:54 AM   #3891
avgor123
avgor123's Avatar
Russian Federation
Your used NBT head unit has the donor car's VIN, and the FSC Codes in it also have the donor car's VIN.
The proper thing to do is flash the head unit and write your car's VIN to it, and then buy from BMW all new FSC Codes for both Nav Application and Voice Control (and SAT Radio, and BMW Apps if needed), and then Import and Activate them in the head unit. This will be very expensive.
The alternative is to use a CIC PnP Activation Module (aka CAN Filter), which will fool you car's CAS Module into thinking the NBT VIN matches CAS VIN, and then you do not need to replace the FSC Codes:
http://www.bimmer-tech.net/shop/bmw-...ivation-module
Hi, Shawn!
I have run SWID Reader on my car. That program show my car's VIN, donor car's VIN (at NBT) but doesn't show FSC code 1B (0 bytes)
What does it mean - FSC 1B wasn't activated at donor car? Or SWID Reader can't read FSC from NBT?
      06-24-2013, 06:29 AM   #3892
shawnsheridan
Hi, Shawn!
NBT Does not have 1B FSC Code. It uses a DE FSC Code instead, and SWID Reader will not read it..
      06-24-2013, 06:44 AM   #3893
avgor123
avgor123's Avatar
Russian Federation
Thanks!
I wish to be sure my NBT has FCS installed before I buy a p-n-p Navi activator.
Maybe I can see that via E-SYS or Ediabas prgs?
      06-24-2013, 06:54 AM   #3894
Bricheun
Drives: F30 328
Damn, I did one step wrong during the KOMBI coding for "M Performance logo"- instead of pressing "Code FDL" in the coding panel. I right clicked the folder and "CODE". An error popped up and now two errors come up on the dash :
1) Drivertrain
2) Fuel Supply
Asking me to drive moderately - I returned everything to default state but still there.
Shawn - can you help or point me in the right direction?
