08-02-2018, 02:33 PM | #1 |
Rep 44
Tire Sizes for 19"
I am looking at a set of wheels with the following sizes/offsets:
F: 19x9.5 +21 R: 19x10.5 +35 The car is a stock height xDrive car, so I was thinking these tires may work: 255/35/19 & 295/30/19. Saw a member was running these on his 340i that was lowered. Any thoughts? |
08-02-2018, 03:33 PM | #4 |
Rep 5,140
The front wheels will be about 3/4" past the fender and the rear wheels at least 1/2" past the fender on stock xDrive height.
Can you share any photos with the wheels on F30? |
08-02-2018, 03:42 PM | #5 |
Rep 44
https://f30.bimmerpost.com/forums/sh....php?t=1518711
I have more pictures on my phone, but they are to large to attach. |
08-02-2018, 03:50 PM | #6 |
Rep 5,140
That F30 is on coilovers and also with added negative camber both front and rear. The tires are also with a lot of stretch, 235 front and 265 rear.
Those wheels will look ridiculous on your F30 with stock xDrive height! |
08-02-2018, 03:50 PM | #7 |
Rep 969
Those are way too aggressive for xdrive and stock height. He also has a lot smaller tires and running a few degrees of camber which gives him more clearance. I would stray away or do more homework if you really want to run those sizes. It won’t look good on stock height.
Beat me to it ^^ I think we literally have the same message |
.BMW.1863.00 |
08-02-2018, 03:57 PM | #8 |
Rep 44
I wasn't worried about what it looked like with stock height, I was stating that I am currently stock height, and if the tires will fit without rubbing. .BMW. said they would stick out 3/4". Is that correct?
I also asked for a suggested offset/wheel size if I was to order the same wheels new? Thanks. |
08-02-2018, 05:43 PM | #9 | |
Rep 4,259
if you are not lowering your car, the wheel and tire size you'll need for your x-drive as follows. 19x8.5 +36 (Face-2) with 235/40/19 up front and 19x9.5 +43 (Face-3) with 265/35/19 rear. the wheel faces will not be as concave because of less width and higher offset. i think it will still look great, though. FYI the wheels cost around $900+ each x 4 = $3600 and will take 4-6 months after it's ordered |
