BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Bootmod3 Stage 2+ E30 octane maps for N55-EWG are now available!
      10-20-2020, 08:51 PM   #45
EstorilMSport
EstorilMSport's Avatar
Drives: 2014 335i M Sport
View post on imgur.com
Originally Posted by ZM2 View Post
Nice. On a Dynojet?
I dyno’ed 15whp less than a PureBoost custom tuned XDI-35 PS2 M2 on 93 with this map, same dyno same day. That was with a beta version of this OTS while tracking down some misfire issues (plugs gapped too tight).
Car feels faster, so I’m guessing I’ll be 5-10whp less on my next dyno run. We’ll see.
Yeah it was a dynojet. Posted the pic which isn’t great quality.
ZM22810.50
      10-20-2020, 09:19 PM   #46
ZM2
Drives: 2017 LBB M2
Nice. On the M2’s we see the Stg 2 E30 map do 400-420whp, just depends on how strong the OEM HPFP is on each individual car.
Get that Dorch Stage 2 on, and you’ll be able to push some big power. My Stage 1 Dorch has been doing great.
      10-20-2020, 10:29 PM   #47
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Do you have logs from any of these runs?
FastF30521.00
      10-21-2020, 06:04 AM   #48
EstorilMSport
https://imgur.com/a/n9KiO6B
https://www.bootmod3.net/log?id=5c6a...90c6410319559b
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection
      10-21-2020, 06:37 AM   #49
Halim@HCP
Denmark
721
Drives: BMW F80 M3
Stage 2+ Racegas OTS map is now available per request from users who did not have access to E85.
      10-21-2020, 09:53 AM   #50
kfardan
kfardan's Avatar
Bahrain
50
Drives: '14 BMW 335i
2014 BMW 335i  [0.00]
I'm getting "Failed acquiring OTS map. Please contact Tech support ............"
Any plan for 93 (98 RON map)?
'14 F30 335i N55 EWG - Speedtech Stage 3 EFR 8374 - BM3 Custom Tune - xHP Flash - BMS Meth kit - Dorch Stage 2 HPFP - ER FMIC & CP
      10-21-2020, 10:12 AM   #51
ZM2
Drives: 2017 LBB M2
I was able to download the Stg 2+ Race Gas map without any issues.
      10-21-2020, 10:59 AM   #52
ctt300
Drives: F30 335i
Had same error and emailed support@protuningfreaks.com and they fixed it as of a little while ago.
kfardan49.50
      10-21-2020, 11:57 AM   #53
designatedposter
Drives: m235i
who's going to be the guinea pig to run the stage 2+ race gas with 93 octane and WMI?
M235i rwd 6mt
      10-21-2020, 12:48 PM   #54
NewCarGuy335i
NewCarGuy335i's Avatar
Drives: Black Sapphire 335i
How long before the PWG version comes out? And what's this about an E47 tune?
      10-21-2020, 01:09 PM   #55
ZM2
Drives: 2017 LBB M2
The new Stg 2+ E30 map is what guys are using with an E47 mix, which is half 93 E10 and half E85 to make mixing simple. The added E content just gives a little extra bump & timing pull protection.
      10-21-2020, 01:19 PM   #56
thejeremyman9
4364
Isnt the PWG turbo already maxed out on the stage 2 maps? Especially after 5k rpm? I'm not sure there are any more gains to be had.
      10-21-2020, 01:22 PM   #57
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
Think it's for the hybrid turbo PWG guys like myself, stock turbo PWG will not benefit nor would it be possible to make a stage 2+ map for them as the turbo is too small.
      10-21-2020, 01:49 PM   #58
NewCarGuy335i
So upgraded turbo is our next best option. That's unfortunate, but most do that anyways so not a big deal. Does that mean a custom tune is still better in our case if we upgrade turbos and fuel pump?
      10-21-2020, 02:07 PM   #59
lens
lens's Avatar
2070
Yes, stock pwg is essentially useless, first mod should be either a PS1/PS2 then you start doing fuel pump and custom tune.
      10-21-2020, 02:16 PM   #60
NewCarGuy335i
Right on just making sure. I thought this map was going to change my plans but I guess not.
      10-22-2020, 06:25 AM   #61
MTWO
Drives: M2
I’d do intercooler then PS1 or PS2
      10-22-2020, 05:43 PM   #62
FastF30
FastF30's Avatar
521
Thank you so much... would it be asking to much if you could do a log for a 4th gear pull on the street... like to see how it compares on Virtual Dyno vs Actual Dyno... Thanks in Advance... It's greatly appreciated...
      10-22-2020, 06:03 PM   #63
EstorilMSport
Yeah it was a dynojet. Posted the pic which isn't great quality.
The first one is a log from my 11.74 run a while back.
https://www.bootmod3.net/log?id=5c37...90c666c88c37bf
This is 3rd gear street log:
https://www.bootmod3.net/log?id=5c31...90c679164a85b4
      10-22-2020, 06:41 PM   #64
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
what turbo?
I don't get how you're hitting boost targets at 6500rpm
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      10-22-2020, 07:00 PM   #65
ZM2
Drives: 2017 LBB M2
IDK man, the timing looks pretty gnarly once you’re up into 4th.
Guess it works for some dyno & street pulls, but I’d back off the custom tune if it were my car and was taking it to the track.
Or, add an HPFP and some more ethanol to see if it helps with the timing pull.
      10-22-2020, 07:01 PM   #66
EstorilMSport
what turbo?
Stock turbo
