10-23-2020, 02:59 PM | #111 |
Rep 7,606
It would be great data if you could log your custom tune, then flash the 2+ E30 map and log that. Ideally both 4th gear pulls. The comparison would be very interesting. E70 is pretty high for the OTS map, but based on the fact that all the logs ive seen on it have pretty negative fuel corrections, it should accommodate more ethanol easily.
10-23-2020, 03:04 PM | #112 |
Rep 1,288
See your in Chelsea... My Mom lives there... she just sold her vette that she has been driving upto her last birthday of 80 years old... She drives crazier than I do... lol... so if you see a Lincoln Suv flying around that's probably her...she loves to drive fast...
Pussiwillow521.00 n55david1295.50 |
10-23-2020, 03:24 PM | #113 | |
Rep 3,696
This OTS is better than the map Cary did for me, but we were only tuning for E47. |
n55david1295.50 |
10-23-2020, 03:27 PM | #114 | |
Rep 3,696
I haven’t tried Stg 2+ Race Gas, yet, but my jump to Stg 2+ E30 from Stg 2 E30 was huge! 50whp on the dyno! |
10-23-2020, 03:33 PM | #115 | |
1296
Rep 3,533
10-23-2020, 03:35 PM | #116 | |
1296
Rep 3,533
10-23-2020, 10:39 PM | #117 | ||
Rep 643
FYI this is stage 2 race gas to stage 2+ race gas.
M235i rwd 6mt
10-24-2020, 12:30 AM | #118 | ||
Rep 2,639
10-24-2020, 10:54 AM | #119 |
Rep 142
Stock HPFP, stock downpipe
Ok just performed a full flash to make sure nothing was wrong with the initial flash. Got a couple 4th gear logs but STFT looks to show needs more adaptation time or maybe more E content. Timing gets a bit pulled up top as well. Does maintain about 20psi to redline. Stays WGDC under 90% till about 5300RPM. Will log again once have more than 5 miles on this flash to see if more adaptation needs to occur. Also HPFP psi target stayed at 2850+ psi and not 2450 psi, so not sure why it is higher than others on stock hpfp and others on this ver 7.1 map in general with all the maps I've tried. 3rd log: https://www.bootmod3.net/log?id=5f94...0b43028e1f96a3 2nd log: https://www.bootmod3.net/log?id=5f94...90c6721a667d74 1st Log: https://www.bootmod3.net/log?id=5f94...729b52119f1d82 Last edited by ctt300; 10-24-2020 at 11:02 AM.. |
10-24-2020, 11:19 AM | #120 | |
Rep 7,606
So bottom line i think it comes down to intended use and personal comfort with running at the limits of hardware. |
10-24-2020, 11:32 AM | #121 | |
Rep 7,606
10-24-2020, 11:46 AM | #122 |
Rep 3,696
Man, I couldn’t use the Stg 2 E30 map below 65F without HPFP drop outs, and had to stick to E25 most of the time.
I think you guys trying the Stg 2+ E30 map with the stock HPFP are nuts! |
10-24-2020, 03:52 PM | #123 | |
Rep 1,288
10-24-2020, 04:59 PM | #125 |
Rep 1,288
Now these numbers jive with what was expected with proper weights etc... You timing is killing your HP in the upper range... Possible cure one-step colder @ .22gap plugs?? ... mix your gas just perfect so you don't crash your pump and plugs and you should have some nice numbers...
You'll see some better pump pressure with a little less corn and maybe some boostane... Maybe your car still needs to adjust... Mine did ... I had logs like this also after just flashing... major change after 50+/- varying throttled miles... In my opinion... this would be in the same ballpark as an actual dyno if this was a flat road run... just my opinion... Thank you sooo much for taking the time to get some usable logs.... Last edited by FastF30; 10-24-2020 at 05:23 PM.. |
10-24-2020, 05:24 PM | #126 | |
Rep 142
Cool beans and I just reset all adaptations and will drive around for a while before next logs. It had way better timing up top before this last full flash so it must be the adaptations holding it back. It was hitting 13.5 degrees on the high end all cylinders. Thanks for doing this! |
10-24-2020, 05:38 PM | #127 | |
Rep 1,288
Looking forward to your new logs... remember cold and dry days are best.. check your future local forecast and plan accordingly.... I do...lol... Last edited by FastF30; 10-24-2020 at 05:54 PM.. |
10-24-2020, 06:14 PM | #128 |
Rep 643
Stock 6mt clutch isn't cutting it.. Thanks for nothing halim! Can you revise tune to increase clamping force on my clutch
I'm either dialing back to regular stage 2 or try the boost reduction option. I've noticed that the stage 2+ wastegate behavior is more boost happy over stage 2. Means less lag when you step on it. Also Means more wmi sprayed. Just noticed the photo is low res. What I'm showing is my rpm spiking at 3000rpm whereas vehicle speed is linear. Iat about 70f
M235i rwd 6mt
10-24-2020, 06:16 PM | #129 | |
Rep 1,288
Mine is the Orange line... |
10-24-2020, 08:24 PM | #130 |
1296
Rep 3,533
did some logs with the 2+ map.. my car hates it.
timing is all over the place, and you can feel it. I kept adding ethanol and it never really improved. really really weird unless I'm getting bad fuel. felt like it was missing etc so.. I'm pissed off right now and shot off a message to Cary Jordan.. my boost is hold well above 6k.. I dunno whats going on.. https://www.bootmod3.net/log?id=5f94...729b518ea8af80 https://www.bootmod3.net/log?id=5f94...90c67183eb9bd8 https://www.bootmod3.net/log?id=5f94...729b518ea8af8a way too much e85 in the tank on the last one.. I never had an issue with boost of fuel pressure.. looks like I may spend the money and switch tuners :/
10-24-2020, 08:48 PM | #131 | |
Rep 3,696
Your post is a bit confusing.
This is the OTS Stg 2+ E30 map? If so, why email CJ about your custom tune? I mean, my CJ feelings can be found here, but just trying to figure out your post: https://f87.bimmerpost.com/forums/sh...9#post26836879 Quote:
10-24-2020, 09:01 PM | #132 | ||
1296
Rep 3,533
Carys map had my boost falling off hard at 6k and ill have fuel pressure issues if I have anything more than e71 in the tank. he keeps saying its fine. the ots map proves that I can make 20psi at 6200+ etc gonna flash back to the cjordan map tomorrow and log and see what happens
