BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > What options do I have for ECU tuning a 2019 440i Gran Coupe Xdrive?
      07-17-2019, 04:38 PM   #1
Gottagofast
Gottagofast's Avatar
391
Drives: 2023 M4 Comp X-Drive
Hello folks. I'm new here. I spent about a week researching options for my situation and e-mailing a bunch of local tuning shops to find out the best option for me but alas, I can't seem to figure it out.
I just leased a 2019 BMW 440i Gran Coupe Xdrive and I was hoping to find an easy and cost effective way to increase engine power without hampering the drivetrain or the cooling system. Since I won't be installing any aftermarket parts on it (It's a lease), I was hoping for a "simple" ECU flash or tune up to achieve just that.
After searching for a while, I narrowed my options down to 3 choices and here they are:
https://www.mgflasher.com/engine/
https://www.tmcmotorsport.com/tuning...tails/10110648
https://www.vividracing.com/tuned-ec...152536712.html
Now I'm not an expert at this. My previous vehicle was a 2016 Cadillac ATS 2.0T which I used a Trifecta tune on and that worked great so I was hoping for a similar option with this BMW.
Which one should I go with and what other options do I have? The local shops here are asking for $1000 + tax with no dyno testing. I have no idea if it's a good deal or not.
Cheers
Edit: Refer to my last post in this thread for the disaster that the tune ended up being.
      07-18-2019, 06:03 AM   #2
BWbimmer
BWbimmer's Avatar
Drives: BMW F36, E36, E93
I would go for the BMW OEM tune. You still got warranty and I guess you don't want to lose it, especially since it is a lease.
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required
Fuller1216.50
      07-18-2019, 09:27 AM   #3
Gottagofast
391
What is a BMW OEM tune? Google doesn't return any results. I doubt the dealer would do such a tune up.
      07-18-2019, 09:47 AM   #4
eddymerckx3
Drives: 2015 328i xdrive sport line
MPPSK
https://f30.bimmerpost.com/forums/sh....php?t=1339568
      07-18-2019, 10:04 AM   #5
BWbimmer
BWbimmer's Avatar
      07-18-2019, 10:10 PM   #6
Gottagofast
391
I'm just looking for a user install-able tune/flash without requiring physical modifications.
      07-18-2019, 11:27 PM   #7
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3042
Drives: 340 6MT, 50e, others
Nice car. Welcome. One con with say BM3 or any of the other/tuners is No warranty.
I'm sorry.
MmmmmM22588.50
      07-19-2019, 01:26 AM   #8
IK6SPEED
Drives: BMW M3 / AH3
You do not need to do any physical modifications for an ECU tune.
However, you will quickly be broken down on the side of the road with a blown Charge Pipe, waiting for a tow to the repair shop.
And hopefully the plastic CP pieces did not get sucked into your engine intake when it exploded. Otherwise, you have an even more serious issue than just a Chargepipe replacement (and you will just blow the plastic OEM replacement again).
      07-19-2019, 01:47 AM   #9
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
This is the a B58, not a N55.. It doesn't suffer from the same charepipe issue, it has take more boost, stock (up to 26lbs). It's also designed to with a flex section and is placed in a location to resist vibration, unlike the N55.
OP, I suggest you hold out a little; Dinan is supposedly working on a flash tune (not a piggyback) that should be out soon, for the B58.
It probably would be offered with some sort of warranty..
      07-19-2019, 10:34 AM   #10
Gottagofast
391
Thanks! Are you talking about this kit?
https://www.dinancars.com/product/d4...440i%20xDrive/
Or is there another version incoming?
      07-19-2019, 10:48 AM   #11
MmmmmM2
MmmmmM2's Avatar
2589
Drives: 2021 M2C
2016 Mazda CX-5  [0.00]
2021 BMW M2C  [0.00]
Originally Posted by eddymerckx3 View Post
I second this....It adds enough power and also won't void your warranty.
      07-19-2019, 10:50 AM   #12
MmmmmM2
MmmmmM2's Avatar
2589
Drives: 2021 M2C
2021 BMW M2C  [0.00]
I thought the charge pipe issue was fixed for the 340i? :
      07-19-2019, 01:02 PM   #13
Poochie
Poochie's Avatar
Drives: 2016 M2
No, it's supposed a flash tune, like BM3.
Dinan Stage 2 Update https://www.2addicts.com/forums/show....php?t=1602773
https://www.bimmerpost.com/forums/sh...php?p=24225142
      07-19-2019, 01:40 PM   #14
Gottagofast
391
I see, I get it now. Is something wrong with the current BM3 F36 tune that would make you suggest waiting for the Dinan tune?
      07-19-2019, 01:46 PM   #15
Poochie
Poochie's Avatar
Drives: 2016 M2
Dinan usually has dealer-support, same as their old piggyback matching 4/50k mile warranty. My dealer in NJ, the service bay is plastered with Dinan promotions.
So, you wouldn't have to worry as much when it comes to warranty issue and possible denial, since a Dinan tune would have its own supplementary coverage.
      07-19-2019, 04:01 PM   #16
dbright03
dbright03's Avatar
Drives: 2017 BMW 340i MPPSK 6MT RWD
As Poochie mentioned, Dianan's coverage is supplementary (typically 4/50k), Just a head's up that this particular part you mentioned (as you may have noticed) does not carry the typical 4/50k mile warranty. It's a one year warranty only. If you're worried about warranty, then this one is probably not worth it. You're better off getting a different Dinan tune.
      07-19-2019, 08:22 PM   #17
IK6SPEED
Good catch.
Yep. So much for detailed reading at 2AM.
Poochie9104.50
MmmmmM22588.50
      07-19-2019, 09:29 PM   #18
arvi604
Drives: F30 328xi SPORT
Bootmod3 stage 1 tune
      07-19-2019, 10:29 PM   #19
MmmmmM2
MmmmmM2's Avatar
2589
Drives: 2021 M2C
2021 BMW M2C  [0.00]
Driving home today in Sport + mode and MPPSK at full howl I can't imagine wanting a faster car. It's fast enough for me now.
      10-09-2019, 09:49 PM   #20
Gottagofast
391
So I went with the 93 Stage 1 BM3 Mod and here are the results with 94 octane fuel as well as the weight of the car with half a tank of fuel:
2000 kilometers on the car and no oil change yet
View post on imgur.com
      10-31-2021, 08:31 AM   #21
BingoTheClown
Drives: 2020 M340i: RIP '18 440i MPPSK
I have a 2018 440i x Drive Gran Coupe and I also have been researching the possibility of getting a tune.
I see that you got yours. Newbie here and I don't even know what I am looking at on those charts haha. Can you let me know - in simple terms . . do you notice a significant improvement after the tune? Was it worth the cost? Are there any drawbacks? Would you do it all over again?
      03-13-2022, 10:46 PM   #22
Gottagofast
391
Post mortem for the BM3 Mod. AVOID.
The power is good and exhaust sound was great. But, after about 6 months, I got some error messages on the dash and battery warnings. Took it to the dealership (didn't tell them I had a tune on it obviously). They said they discovered lots of oil and gas mixing in the cylinders, reset the car back to factory (removing the tune), and handing the car back to me.
I didn't bother putting the tune back on. The car drove fine for about another year, and then suddenly, I heard a loud noise and a pressure vessel losing pressure in the car with the AC immediately turning hot.
Took it to the dealership, they told me the engine belt had "melted" and on its way out it basically destroyed the AC compressor and parts of the water pump. Cost about 7K to fix and voided the vehicles warranty.
Absolutely would not recommend this tune, or any other for the simple fact that even an extra 60-70 bhp with no modification to the drivetrain can cause this sort of thing.
PS: Only ever did 1 track day with this car and it was in the wet.
2019, 440i, bmw, f36, gran coupe 4 series, xdrive
