09-11-2018, 02:15 PM | #1 |
Rep 928
What Ltd slip is everyone running?
Factory or team mfactory that ecs sells? What's the best to install one into our diff or replace the whole third member? What's the best setup and most cost effective? Thanks
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
09-11-2018, 03:26 PM | #2 | |
Rep 10,473
09-11-2018, 03:33 PM | #3 | ||
Rep 928
09-11-2018, 03:46 PM | #4 |
Fool
1857
Rep 3,542
M Performance, love it.
I'll elaborate on that actually, I love it in my 340i MPPSK. I had a 420D (your 428D) as a loaner for a few days and even that would have really benefited from a LSD. Have RWD, get LSD IMO.
09-11-2018, 04:17 PM | #5 |
Rep 5,372
Most cost effective? The M Performance LSD by a mile. You can pick them up for slightly above/below $2,000 new from various BMW parts vendors. Install at a BMW dealer will run 3.5 hours (book time). I got mine from my BMW dealer (price matched Sun BMW) and I had them do the install (~$500).
The clutch-based MP LSD is a great LSD for street and typical street-driven car track use. The LSD is built for BMW by probably the best clutch-type LSD builder in the world. If you want deeper gearing and/or a different LSD type, then you'll have to have one built by one of the few LSD builders. You'll often pay dearly for it though as most spend in excess of $3,000 to have one built to their specs by the typical LSD builders. If you have increased the boost, deeper gearing really isn't necessary as the additional low and mid-range power makes up for the lack of gearing torque multiplication.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
09-11-2018, 04:25 PM | #6 | |
Rep 928
09-11-2018, 04:26 PM | #7 |
Rep 928
Agree 100% it's just bs bmw didn't put one in the f30's.
09-11-2018, 08:53 PM | #8 |
Rep 2,358
Quaife is also an option. I made some videos about my first impressions and comparison with the BMW E-diff. Unless you are VERY serious about track times or drifting I don't think a diff is worth the money over the E-diff.
(A Dane in China) |
aps335.50 |
09-11-2018, 10:19 PM | #9 |
Rep 928
Ediff? Mine has an electronic traction control that is nothing even close to a Ltd slip?
09-12-2018, 12:20 AM | #10 |
Rep 2,499
I believe he's referring to the ADB, Active Differential Brake. It's just a brake based torque vectoring system. It's good enough to lay two strips of rubber on the ground, but it doesn't feel anything like a real LSD.
09-12-2018, 03:22 AM | #11 |
Fool
1857
Rep 3,542
It is in no way a replacement for a LSD, once you've driven both on a daily basis, most people will realise the two are not comparable. Pulling out of junctions with gravel on the road in the 420D *WITH* the 'ediff' enabled was still a messy affair with just one wheel spinning whereas with a real diff, it just went.
09-12-2018, 07:23 AM | #12 |
Cheapskate
4450
Rep 4,993
Isn't the MPerformance LSD an "E-Diff" but with real LSD operation i.e. the clutches are electronically controlled rather than mechanical like Quaife? I think I'd prefer one that is mechanically operated vs one that's trying to sense slip and move power around via computer programming.
09-12-2018, 07:47 AM | #13 |
Rep 775
M LSD.... $2k plus install.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
09-12-2018, 07:51 AM | #14 |
Rep 928
That's my price cap. I would like to know how much labor to install a wavetrac or one of the 1k dollar Ltd slips from ecs?
09-12-2018, 08:21 AM | #15 | |
Rep 3,211
kern4174449.50 |
09-12-2018, 09:32 AM | #16 |
Cheapskate
4450
Rep 4,993
Yeah you're right. I found some more technical documentation detailing how it works. I don't know where I saw that previously. Maybe on the F80?
Edit: Yep, this is what I am talking about. It's actuated by an electric motor that adjusts engagement based on sensor feedback. https://f80.bimmerpost.com/forums/sh....php?t=1018024 |
insanecoder1412.00 |
09-12-2018, 11:31 AM | #17 | |
Rep 3,211
I believe the active M diff is coming to the G20 at least in the M340i they need it to be able to tout the G lineup as a driver's car capable of going up against ATS and Giulia et al. the rest of the lineup will likely lack the LSD and be the mushy ole cars we complain about |
kern4174449.50 |
09-12-2018, 12:36 PM | #18 |
Rep 963
09-12-2018, 01:05 PM | #19 |
Rep 775
$500 as i recall. There is a specialized tool or two to install it, so check with indy if you plan go with ANY LSD by any manufacture.
Enjoy the Drive,
09-12-2018, 01:09 PM | #20 | |
Rep 775
Again, HUGE thanks for your video efforts.
Enjoy the Drive,
09-12-2018, 02:30 PM | #21 | |
Rep 928
09-12-2018, 02:42 PM | #22 |
Rep 775
Enjoy the Drive,
