BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > What gauges do you run in your bootmod3 dashboard?
European Auto Source (EAS)
      04-25-2018, 12:09 PM   #1
deezeedee335
deezeedee335's Avatar
28
Drives: 2013 F30 335i PWG
Just wanted to get a feel for what gauges people are using in there bootmod3 dashboard.
I also have a question on a few of the gauges.
- What are the difference between the three boost gauges. Boost (Pre-Throttle), Boost Pressure (Deviation) and Boost Pressure (Target)?
-What is the difference between the three different AIT gauges?
-What is the difference between the three MAF gauges?
There seems to be some duplicates items you can select and I am unsure which one is the correct one to look at or if it even matters.
      04-25-2018, 12:42 PM   #2
JaredG_F30
JaredG_F30's Avatar
925
Boost pre-throttle is the boost pressure measured in the charged air system just prior top the throttle plate.
Boost target (or commanded) is the boost pressure the DME wants
Boost deviation is boost target - boost (pre-throttle)
I'm assuming you meant IAT, not AIT! There must be two sensor locations for measuring intake air temps. I'm assuming the default IAT PID chosen is located in the intake air manifold. I'm not sure about the other one.
MAF, of mass air flow, measures the amount of air being sucked through the intake. I'm not sure why there are 3.
I run IAT, ignition Cyl 1, boost (pre-throttle), coolant temp, EGT, knock detected, oil pressure
SPI Films Blog/DIY Vids
      04-25-2018, 02:01 PM   #3
deezeedee335
28
Thanks for the explanation!!! And yes it was a typo, I meant to say IAT!!
Also can you explain EGT?
2013 F30 335i PWG
VRSF DP/ VRSF FMIC/ ER CP/ AFE Intake Filter/ PowerStop Brakes/ Custom Exhaust/ BM3 Stg 2/ AEM Water Methanol Injection/ MotorSports Hardware Studs, Locks and Spacers
badbread297.00
      04-25-2018, 02:27 PM   #4
BMWcurious
Drives: Various BMWs
EGT in the case of the N55 is a modeled value used in an exhaust gas expansion model to calculate the exhaust fractions required through the turbine and the wastegate (hence calculating the required wastegate position). It is also used in fuel calculations.
      04-25-2018, 05:55 PM   #5
alex_j_5
14 335i M Sport EB II | VRSF 5" HD FMIC / CP, AWE
25
Drives: 335i m sport
Just wondering what is a good range of IAT to know your fmic is doing a good job ?
14 335i M Sport EB II | VRSF 5" HD FMIC / CP/ DP, AWE AXLEBACK, BM3 Stage 2
      04-25-2018, 06:34 PM   #6
deezeedee335
28
That is a good question!!! I have the same FMIC as you and I am usually about 10 degrees higher that outside temp.
Don't really know if that is good or not??
      04-25-2018, 08:35 PM   #7
JaredG_F30
JaredG_F30's Avatar
925
Exhaust Gas Temp
      04-25-2018, 08:36 PM   #8
JaredG_F30
JaredG_F30's Avatar
925
Also this^
      04-27-2018, 10:28 PM   #9
FSociety
2020 X3M/X4M Coming Soon
FSociety's Avatar
Drives: F90 M5, F80 M3 ZCP
Dashboard itself I keep it simple, defaults +/- some adjustments
Oil Temp +
F90 M5 @BM3Tuning/HCP Stg1 6.6s | 10.3@134 | 0-60 2.61s | HCP Stg2 60-130 6.1s 10.1@138
F98 X4MC
http://www.instagram.com/BMWF9XM
      05-02-2018, 08:55 PM   #10
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [5.00]
can someone please enlighten me on how to properly monitor oil pressure? I've added it to my gauges seeing as how the more I read about modding turbo cars, the more people talk about how critical oil pressure is. What is a good level? I'm looking at the read out and realizing I have no clue if I'm good or not lol.
      12-02-2019, 08:12 PM   #11
enlimalima
Drives: 335i F30 PWG
So what is the actual boost? And when you upgrade turbo and "increase" your boost (say to 20/21psi) do you increase the pre-throttle or DME target?
How do you know if the boost is working well?
      12-02-2019, 09:08 PM   #12
johnung
A quick way to add a real-time boost or other gauges is to purchase and plug in one of these Bluetooth connectors into your OBD2 port near the driver's left knee. Please see attached photos. It has phone apps to add gauges and performance testing like 0-60mph and 1/4 mile. Inexpensive and works well!
      12-02-2019, 11:27 PM   #13
thejeremyman9
What are you using for datalogging/monitoring?
In MHD, you can see boost target, boost pre throttle, and boost manifold. You want to compare boost in the manifold vs. boost target. +/- 1 psi deviation is considered normal. More than that you might have a leak or other issue.
The manifold boost is the "actual" boost the engine is seeing. Boost pre throttle will be the same when the throttle is open 100%, but just because you have the pedal at 100% that does not mean the throttle is fully open. Some tunes regulate throttle position to control boost, engine load, etc.
You will not target higher boost simply by bolting on a bigger turbo. You need a tune that targets higher boost. You take advantage of the bigger turbo by targeting a higher boost that is not possible with stock turbo (over simpifying because a bigger turbo will generally make more HP than a smaller turbo at the same boost level, but thats the general idea). If you increase pre-throttle or manifold boost without increasing DME target that would be overboosting... your tune should not do that.
