04-25-2018, 11:09 AM | #1 |
Rep 86
What gauges do you run in your bootmod3 dashboard?
Just wanted to get a feel for what gauges people are using in there bootmod3 dashboard.
I also have a question on a few of the gauges. - What are the difference between the three boost gauges. Boost (Pre-Throttle), Boost Pressure (Deviation) and Boost Pressure (Target)? -What is the difference between the three different AIT gauges? -What is the difference between the three MAF gauges? There seems to be some duplicates items you can select and I am unsure which one is the correct one to look at or if it even matters. Thanks |
04-25-2018, 11:42 AM | #2 |
Rep 1,499
Boost pre-throttle is the boost pressure measured in the charged air system just prior top the throttle plate.
Boost target (or commanded) is the boost pressure the DME wants Boost deviation is boost target - boost (pre-throttle) I'm assuming you meant IAT, not AIT! There must be two sensor locations for measuring intake air temps. I'm assuming the default IAT PID chosen is located in the intake air manifold. I'm not sure about the other one. MAF, of mass air flow, measures the amount of air being sucked through the intake. I'm not sure why there are 3. I run IAT, ignition Cyl 1, boost (pre-throttle), coolant temp, EGT, knock detected, oil pressure
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids Last edited by JaredG_F30; 04-25-2018 at 11:47 AM.. |
04-25-2018, 01:01 PM | #3 | ||
Rep 86
Also can you explain EGT?
2013 F30 335i PWG
VRSF DP/ VRSF FMIC/ ER CP/ AFE Intake Filter/ PowerStop Brakes/ Custom Exhaust/ BM3 Stg 2/ AEM Water Methanol Injection/ MotorSports Hardware Studs, Locks and Spacers |
badbread332.50 |
04-25-2018, 01:27 PM | #4 |
Rep 182
EGT in the case of the N55 is a modeled value used in an exhaust gas expansion model to calculate the exhaust fractions required through the turbine and the wastegate (hence calculating the required wastegate position). It is also used in fuel calculations.
04-25-2018, 04:55 PM | #5 |
14 335i M Sport EB II | VRSF 5" HD FMIC / CP, AWE
30
Rep 100
Just wondering what is a good range of IAT to know your fmic is doing a good job ?
14 335i M Sport EB II | VRSF 5" HD FMIC / CP/ DP, AWE AXLEBACK, BM3 Stage 2
deezeedee33532.00 |
04-25-2018, 05:34 PM | #6 |
Rep 86
04-25-2018, 07:35 PM | #7 |
Rep 1,499
deezeedee33532.00 |
04-25-2018, 07:36 PM | #8 |
Rep 1,499
Also this^
deezeedee33532.00 |
04-27-2018, 09:28 PM | #9 |
IG @bmwF9xG80
3813
Rep 7,593
Dashboard itself I keep it simple, defaults +/- some adjustments
Oil Temp +
60-130mph 6.5s X4M #HCP
deezeedee33532.00 |
05-02-2018, 07:55 PM | #10 |
Rep 1,117
Drives: 2015 BMW M235i
can someone please enlighten me on how to properly monitor oil pressure? I've added it to my gauges seeing as how the more I read about modding turbo cars, the more people talk about how critical oil pressure is. What is a good level? I'm looking at the read out and realizing I have no clue if I'm good or not lol.
deezeedee33532.00 |
12-02-2019, 07:12 PM | #11 | |
Rep 41
How do you know if the boost is working well? |
12-02-2019, 08:08 PM | #12 | ||
Rep 5,399
12-02-2019, 10:27 PM | #13 | |
Rep 7,622
In MHD, you can see boost target, boost pre throttle, and boost manifold. You want to compare boost in the manifold vs. boost target. +/- 1 psi deviation is considered normal. More than that you might have a leak or other issue. The manifold boost is the "actual" boost the engine is seeing. Boost pre throttle will be the same when the throttle is open 100%, but just because you have the pedal at 100% that does not mean the throttle is fully open. Some tunes regulate throttle position to control boost, engine load, etc. You will not target higher boost simply by bolting on a bigger turbo. You need a tune that targets higher boost. You take advantage of the bigger turbo by targeting a higher boost that is not possible with stock turbo (over simpifying because a bigger turbo will generally make more HP than a smaller turbo at the same boost level, but thats the general idea). If you increase pre-throttle or manifold boost without increasing DME target that would be overboosting... your tune should not do that. |
beeyar16.00 |
09-12-2020, 03:16 PM | #14 | |
Rep 89
09-13-2020, 12:31 PM | #15 |
Rep 7,622
09-14-2020, 07:24 PM | #16 |
Rep 2,369
If you don't know what to run then you don't need them
(A Dane in China) |
09-16-2020, 02:19 PM | #17 | |
Rep 67
09-16-2020, 04:17 PM | #18 |
Rep 7,622
Make sure its more than 0.
Kidding, but indeed it is not very talked about. You might want to just peek at other people's logs to get a general idea about what it should be at different RPMs. I would say the main idea for monitoring in real time is to make sure you dont have a sudden drop or significant deviation from your normal operating range (after confirming your normal operating range is on par with other N55s) that could suggest a mechanical issue, oiling issue, etc. |
09-16-2020, 09:20 PM | #19 |
Rep 2,369
Having a gauge showing oil pressure will likely not save you IF it suddenly dropped dramatically so I think it is rather pointless.
Idle is ~45psi and it will increase with load and RPM to ~85psi.....and drop to ~22psi during emergency braking. https://datazap.me/u/harkes/low-oil-...data=2-3-14-17
(A Dane in China) |
09-16-2020, 09:24 PM | #20 |
Rep 2,369
I only use the gauges BEFORE going WOT to check oil temp and IAT. Keep your eyes on the road when you floor it!!!
(A Dane in China) |
