09-15-2019, 04:36 PM | #23 | ||
Rep 231
09-15-2019, 07:04 PM | #25 |
Rep 127
09-15-2019, 07:48 PM | #26 | |
Rep 1,369
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
09-15-2019, 08:44 PM | #27 | ||
Rep 964
09-16-2019, 05:22 AM | #28 |
Rep 1,239
09-16-2019, 07:06 AM | #29 |
Rep 1,597
Any of the brand ceramic insulators can crack and cause this problem. MP is just saying whoever installed it damaged the plug or it was just a bad plug already cracked.
09-16-2019, 09:18 AM | #30 | |
Cheapskate
4447
Rep 4,993
So I'll throw it out there again. Until I see a bunch of people failing with stock plugs on the B58, there's no reason to change them IMO. All I see are people changing them based on recommendations, or running fine on stock plugs. I have yet to see anyone having issues with stock plugs that were fixed by swapping replacements. I feel like it's just a default recommendation from the n-series engines that needed it. |
B58togo808.50 |
09-16-2019, 06:20 PM | #31 | |
Rep 1,219
09-16-2019, 06:22 PM | #32 |
Fool
1857
Rep 3,542
I'll chime in here. I have a 340i MPPSK at 55K miles. Plugs were done at 38K and since then I had problems when it was very wet outside - I had a horrible misfire to the point where I thought the engine was going to suicide itself. This happened a total of three times (two very near service requirement) so brought this up at the next service and then the fun started.
They ended up keeping the car for 4 weeks with no resolution. They weren't able to replicate the issue (that seemed to only happen in heavy rain) and there were no errors logged. They managed to get it to 'hiccup' once while idling but helpfully the workshop team weren't aware of the test and there was no monitoring going on (again, no errors). After 4 weeks they'd decided nothing was wrong, BMW UK was no help but I managed to convince the dealer to perform a compression and leakdown test which came back fine. After this, I was essentially forced to collect the car despite not trusting it. I collected the car, pretty pissed off that nothing had changed. Engine was up to temp so I knocked it into second and floored it. Bang, again we had the same horrible misfire. The engine sounded like shit and there was no power but this time I had a drivetrain error. Took it straight back to the dealer pretty pissed off and they took it off me and gave me a loaner to get home. The next day they told me they'd replaced spark plugs 1 and 3 as testing had shown they were faulty. They replaced them under the parts warranty from when they were previously done and sent me on my way. It ran 'ok' but it wasn't the same. I had a very noisy comfort mode, it wasn't as smooth and it just didn't have the torque it used to have. Today I swapped the plugs out. Cylinders 1 and 3 had NGK SILZKGR8B8S with BMW branding on them, the others had Champion. One of the Champions appeared to have a crack, another had a more dirty electrode than the others. I have now put in 6 brand new NGK SILZKGR8B8S and driven it for a while. The difference is quite stark. It's now MUCH smoother, much quieter and has regained its torque and seems to have gained responsiveness. If you had told me it was a different engine, I think I would have believed you. I have retained all old plugs and labelled them just in case but for now I think I'm good.
janea120728.50 xxxjecxxx2153.00 |
09-16-2019, 07:46 PM | #33 | |
Rep 4,876
Does it suck, sure. Is it MP's fault or the plugs they sell, not at all. All I'm saying, point the blame at the proper location here. |
B58togo808.50 |
09-16-2019, 10:05 PM | #34 | |
Rep 1,369
PURE340i104.00 |
09-16-2019, 10:09 PM | #35 |
Rep 32
A damaged/cracked spark plug would have had issues under high load/even at idle when first installed. Having driven for so long before having issues, sounds like maybe extreme detonation may have occurred causing damage to the plugs. Maybe bad fuel? I have over 28,000 miles and have been running jb4 on map 5 and now bef/race gas on map 5 since 800 miles with the original champion plugs and have not had any issues.
09-16-2019, 10:11 PM | #36 | |
Rep 1,369
09-16-2019, 10:13 PM | #37 | |
Rep 1,369
09-17-2019, 05:31 AM | #38 |
Rep 1,239
09-17-2019, 06:36 PM | #39 |
Rep 1,219
I would ask BMW to see the plug, I wonder what specifically fell in... center electrode or ground electrode...
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
09-17-2019, 06:56 PM | #40 |
Rep 4,876
Probably not much to the plugs since that's on the way out of the engine. I would argue that your turbo is feeling the brunt of that pain, and one day might be just as unhappy as the OP's engine.
09-18-2019, 07:03 AM | #42 | |
Rep 1,597
09-18-2019, 09:59 PM | #44 |
Rep 2,964
