BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > App for obd reading
      12-03-2019, 11:01 PM   #1
Tpriest7893
Drives: Bmw 335i f30 N55
App for obd reading
based on some research, I want an app to read codes that don't show. My car has a rough idle only on a cold start and I want to check and see if any codes are being thrown that don't pop up.
Bimmerlink- sounds good but has mixed reviews.
OBDfusion- looks good but not designed specifically for bmw.
Any others thst I can use or any comments on these?
Thank you.
Car has always hesitated a little on cold start. After upgrading charge pipe and larger intercooler it has gotten worse. Car drives phenomenal tho. No issues, hesitations, any lag, just that damm cold start.
-Tods
      12-03-2019, 11:41 PM   #2
thejeremyman9
Drives: 2015 BMW 335i
I assume you dont have BM3 or MHD?
I thought that MHD allowed you to read codes without purchasing any of the modules. Could be wrong though. I believe you would still need the bimmergeeks cable, however. Worth checking.
I don't think torque pro would show hidden codes, but that is what i use for datalogging and reading on my other cars.
      12-03-2019, 11:48 PM   #3
Tpriest7893
I should of been more specific my bad.
No, at the moment I am fully bolted. No tune. I plan to tune just haven't yet
-Tods
      12-04-2019, 12:12 AM   #4
thejeremyman9
I figured as much, but i thought that the MHD app, which is free, allows you to read codes without purchasing anything. You just need the monitoring module to monitor/datalog, and of course flasher module to flash. I would check that out to verify.
Torque pro is only 5$ and is an awesome app, only requires a cheap OBD2 bluetooth/usb/wifi adapter, and can datalog, monitor, and read codes, but is not BMW specific and may not read shadow codes.
      12-04-2019, 11:24 AM   #5
Phyrexia
Resident Pedant
Drives: '15 335i 8AT
xHP and MHD will both read BMW codes without spending any money.
Torque Pro is excellent.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+
