09-19-2020, 11:25 AM | #1 |
Rep 88
Drivetrain vibrations
Hello guys , ever since i got my car sometimes i get very bad vibration in the entire car at idle with i put the gear on D especially it gets worse, can notice slightly mn park, the car vibrates very bad when i turn the AC on, I thought that would be from engine mounts but I removed them and the mechanic said they are fine no faulty ones, what could be the reason? It's like this for more than 2 years , sometimes the problem is there sometimes not that's why I haven't bothered myself getting it fixed.
Bmw 328i n26 2016 with 60k miles |
09-21-2020, 08:28 AM | #2 |
Rep 36
Drives: 2015 F36 Gran Coupé 428iX N20
I would get it checked out if you have warranty still. would rather be safe then sorry at that point
Nathen Wheten
BMW/MINI Moncton |
09-23-2020, 12:36 PM | #3 |
Rep 5,457
Any updates on this?
Ive experienced a similar issue with both N20s that Ive owned. |
09-23-2020, 05:11 PM | #4 | |
Rep 21
09-28-2020, 12:26 PM | #6 | |
Rep 5,457
With the way manufacturing and quality control is these days, they truly have this sort of thing down to a science. Recently refreshed my NGK 97506 and checked gap quickly before install just because. They were all bang on. |
09-28-2020, 12:29 PM | #7 |
Rep 5,457
@Ahmaddoski
Any updates on your situation. Im positive this is not an ignition issue (at least in my case). Wondering what you may have come up with. |
09-28-2020, 11:37 PM | #8 |
Rep 232
I'm having similar issue with my N20 alos, I have vibration when the engine is in gear but not in park. If I turn the AC on when it's in gear there is no vibration. I used ISTA to increase RPM by 50 when in gear, this fixed the vibration in gear issue. I already replaced spark plug, injector, fuel pump, belt tensioner, cleaned the vavle and still same problem.
sspade2464.50 |
09-30-2020, 07:10 PM | #9 |
Rep 88
Ever since posting this thread i was busy going from one mechanic to another one and different scan tools , no one knew the issue changed ignition couls too checked engine and tranny mounts all ok , my spark plugs were changed as i said , removed injectors from the car and tested and cleaned them on an Gdi injector cleaning and testing machine a shop had here, checked fuel pump and their filters all ok, I really can't think of anything else right now idk what to do i installed bosch spark plugs am thinking of replacing them with ngk this time but ihave spend hell alot of money on this car and its not fixing up 🤦🏻*♂️
sspade2464.50 |
09-30-2020, 07:27 PM | #10 |
Rep 5,457
Thanks for the update, thats all very good info for the group.
Keep us posted if anything changes. |
Ahmaddoski16.50 |
10-03-2020, 01:39 PM | #13 |
Rep 88
Hello guys, i tried to do a diagnose myself at garage today i noticed somthing when i put the car on gear the engine mount goes down slightly is it normal to be like that or it's shut ? Here is the video you can notice with the movement of turbo actuator
sspade2464.50 |
