BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Folding Mirror Retrofit Done
      02-04-2019, 04:27 AM   #1
kingmonkey8
Drives: BMW 428i
I did the retrofit for the Folding Side Mirrors for my F32.
So I bought the folding mirrors and mirror switch box with folding button.
After reading the tutorials on the forum it seemed like cars with non folding mirrors have 6 pin connectors and there is some re-wiring or wire cutting/tapping needed from the mirror switch in order to get the passenger mirror to work as the folding mirrors have 5 pins. But the information is not very clear.
However when I removed my door mirrors, I found my mirrors actually had 5 pins and not 6. I was expecting it to have the 6 pins.
I checked the wires to the switch box and it had the wires 1,2,3,4,10,11 but not the 7,8,9 that goes to the passenger mirror.
When I plugged in the mirrors, I was suprised the mirror adjustment controls worked for both sides. With passenger side auto reverse dip also working. So the mirrors must be controlled via the FEM
I then coded in the option 430 and VO coded FEM Body and the mirror folding now works. Also the anti dazzle on drivers side works.
My car has auto dimming rear view mirror and electric memory seats so appears that if you already have the mirrors with 5 pins, apart from coding the folding mirrors, the wiring is already there and is almost plug and play. No re-wiring neccessary.
I was glad it turned out so straight forward without having to cut or re-wire the loom and think it's a retrofit definitely worth doing.
The only thing I have noticed is the mirrors don't fold at exactly at the same time.
Poochie9104.50
      02-04-2019, 04:49 AM   #2
Simon89
Simon89's Avatar
Drives: F30 330D XDrive
Where are you checking to see if the car has either 5 or 6 wires?
13' F30 330D XDrive
      02-04-2019, 05:02 AM   #3
kingmonkey8
Drives: BMW 428i
You can check the connector on the mirror itself. Some have 6 pins and some have 5 pins.
Also the pin configuration on the mirror switch box will be slightly different as the wire configuration is different.
      02-23-2019, 11:53 PM   #4
Jhnblckwood
Drives: F30 2014 320i xdrive
How bad is the delay? I got one mirror and will b getting the other n doing this soon. My ocd may kill me if they don't fold at same time. Lol
      02-24-2019, 04:44 AM   #5
kingmonkey8
Drives: BMW 428i
It's only like for a split second.
Have you checked how many pins your mirror has?
Have you bought the window switch?
      02-26-2019, 06:50 AM   #6
Jhnblckwood
Haven't opened up the mirror yet n no haven't bought the switch.
      02-26-2019, 06:51 AM   #7
Jhnblckwood
This is the one I bought.
      02-26-2019, 07:18 AM   #8
kingmonkey8
Drives: BMW 428i
Depending on the mirror connector on your car. If it has 5 pins it should be plug and play. If it has 6, then you will need to re-wire it for the passenger side.
Most of the window switches have broken tabs as they are difficult to take them out without breaking the tab. But you can just buy the surround from BMW for less than £20.
The auto fold mirrors should come with the dimming glass. But on later cars only the drivers side has the dimming feature. If you want it for the passenger make sure the mirror has got the dimming glass.
      02-26-2019, 05:42 PM   #9
Jhnblckwood
Thanks man. I hope I have 5 pins lol I'm aware of bmw cheating out on the passenger side in the recent years. I don't get it but whatever. So ur saying the window switch is only 20$?
      02-26-2019, 05:48 PM   #10
kingmonkey8
Drives: BMW 428i
Not the switch, but the surround that clips into the door.
It's two pieces, the switch and the surround.
Most of the switches for sale had broken clips. But it's easily replaced. TBH it doesn't make much of a difference.
If you have electric memory seats with auto dim rear view mirror then you might have the 5 pins.
      02-26-2019, 05:51 PM   #11
Jhnblckwood
Oh ok. I got u. Thanks man.
I do have electric/heated seat w memory and auto dim interior mirror but I retrofitted the mirror.
      06-03-2019, 03:49 PM   #12
bmhewett
Drives: 3012 328i sport 6 speed MT.
i want to have folding mirors
hello, i'm glad you finally have folding mirrors, i want to do the same to my car, do you have the parts numbers? two mirrors and door swith.
thank you
      06-07-2019, 10:23 AM   #13
SoCalCarGuy
Drives: 2019 440ix cpe + 2018 x4 m40i
ummm...I used Bimmercode to make my mirrors close. took 5 min with my phone and wifi dongle.
      11-18-2019, 08:45 AM   #14
odessa
Drives: BMW 435d XDrive
Code
Hi, new to this forum.
Just traded my F10 535d for 435d Xdrive and want to do this mod.
Can I ask what you coded the car with ?
Is there a how to guide anywhere
Thanks
Jay
      11-19-2019, 05:10 AM   #15
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
If anyone is looking for a mint set of OEM F32/F33/F36 Shadowline Mirrors-Complete, with all options - I have a set FS
https://f30.bimmerpost.com/forums/sh....php?t=1556363
      07-28-2020, 07:17 AM   #16
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
I have a mirror set for sale. Take a look at the link below and pm me if interested. Thanks!
FS: f30 exterior mirros https://f30.bimmerpost.com/forums/sh....php?t=1743430
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      02-14-2022, 09:48 PM   #17
JohnnyGFitness
Drives: Black on Black 328xi Coupe
Hello friends of BMW,
I have a 435ix I beemer coded this on my car when it never did. I had all the functions on the driver side switch. Does anyone know on a 2018 X2 f39 with all the heated seats, memory seats, m sport package, but no switch on the driver side window switch, be able to just beemer code the folding windows? I just bought this car for my wife, and I’d love to fold mirrors in to prevent damage into the garage where I rent at.
I appreciate all your help.
      02-15-2022, 01:24 PM   #18
Jhnblckwood
If u don’t have the folding mirror switch on driver side then u don’t have motorized folding mirrors. First install them then u can do it.
      11-25-2022, 04:23 AM   #19
arsenal6
Drives: bmw 428xi
2015 bmw 428xi  [0.00]
Are all of these interchangeable? Or is it better to take it off a similar vehicle
      04-06-2023, 07:59 AM   #20
uali23
Drives: BMW F30
I just wanna ask. Does the f32 mirror mounting points fit the f30?
      08-25-2023, 02:21 AM   #21
arsenal6
Drives: bmw 428xi
Could you let me know what your options list looks like?
If I don't have to do the wiring, it be godsend. I am looking to do this retrofit sometime next year.
