09-17-2019, 08:10 AM | #2927 |
Rep 1,240
Drives: 2016 BMW 340i
shawnsheridan & Fus10nv2 Thank you for your suggestions. I am using a laptop that I don't want to mess around with the dates. So, for now, I went with E-Sys 3.27 and E-Sys Launcher PRO 2.8.2, fully understanding that is has limited validity.
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
09-17-2019, 08:12 AM | #2928 |
Rep 40,727
09-20-2019, 01:16 PM | #2930 |
Rep 40,727
PM sent.
09-23-2019, 12:31 PM | #2931 |
Rep 188
Drives: 2013 328i xDrive
I need PSdZData Full version for executing TAL
09-23-2019, 12:38 PM | #2932 |
Rep 40,727
09-23-2019, 01:32 PM | #2934 |
Rep 40,727
What exactly do you mean, as you can code and flash DME with E-Sys same as you can any other ECU.
caja880.00 |
09-23-2019, 02:44 PM | #2935 |
Rep 40,727
E-Sys is not Tuning software itself. You can write modified firmware files (BTLD and SWFL) to DME/DDE with E-Sys, although besides using other software to edit them, I am not sure how the signature / validation is maintained or the validation check bypassed.
caja880.00 |
09-23-2019, 06:40 PM | #2936 |
Rep 396
It took a bit faffing around, but eventually I managed to get everything working using the following setup:
E-Sys Launcher Premium V2.8.2.155 E-Sys V3.27.1 v.4.19.21_PSdZData_Lite Rearm 204 but... even with the latest PSdZData_Lite, I keep getting [C012] error when trying to read CAFD for DSC (on F22): DSC [29] [VXXXXXX] readCPS o.k. CAFD_000019CC_100_125_001 Fehler: File for "cafd_000019cc-100_125_001" not found! [C012] Other modules read fine and I also have the latest PSdZData_Lite. The istep on the car is: F020-16-03-504. What am I doing wrong? Do I need a different PSdZData? Any help would be much appreciated. Thanks! *UPDATE* Nevermind; It was currupted PSdZData files - copied them again and it worked like a charm! Last edited by mastrchee; 09-23-2019 at 07:21 PM.. |
09-24-2019, 07:08 AM | #2939 |
Rep 40,727
PM sent.
09-24-2019, 07:12 AM | #2940 |
Rep 40,727
Sorry, old versions are not maintained. You can use latest PSdZData version. You do not need to reply on older 18-03 to load .bin files via USB. There are newer ENET solutions.
09-24-2019, 06:57 PM | #2943 |
Rep 40,727
PM sent.
09-27-2019, 03:23 PM | #2944 |
Rep 1
Hi shawnsheridan ! I'm new to this forum and BMW coding, so far I've been able to use the ENET + ESYS 3.33 and psdzdata files from older posts to connect to my F30 335i. However I can't read/write any data for HU_NBT. I'm assuming I need some token, but I haven't been successful in this process. Is there an older post or walkthrough that you can direct me to?
09-27-2019, 06:30 PM | #2945 | |
Rep 40,727
10-06-2019, 07:51 AM | #2947 |
Rep 40,727
PM sent.
10-07-2019, 04:50 AM | #2948 |
Rep 2
Need help with 6wb on my f30
I’m new at this,bought a 6wb cluster for my f30 and installed my self,but still need to use E-sys to code car to accept it (was told cluster was preprogrammed by my vin# when I bought it) I have a laptop and e-cable, guy from Europe was suppose to remotely take control of my laptop to code my car,he said I needed “PSDZ” still waiting on him to do this for me,was wondering if this is something I could do my self as cluster only shows mph and color/scheme change for modes, but gas gage and hud isn’t working along with rpm,temp,gear,etc plus a lot of warning messages in German. Any help would be greatly appreciated as I really don’t know what I’m doing and don’t want to mess up my car.
