12-23-2021, 09:21 PM | #1 |
Rep 9
Down pipe fitment help
Hi guys, I'm trying to install a ER down pipe on a n26 428i. It seems the upper end doesn't fits perfectly to the turbo and there is a little gap. Is it a problem? Can I just fasten the clamp to move it at a correct position? This is the position when the two screws are in their place.
12-24-2021, 04:38 AM | #3 |
Rep 5,457
Drives: F30
Hm. Assuming you checked to make sure gasket is properly seated?
You're going to want that to sit flush, no gap. The V Band clamp may help shore up the gap when you tighten it down… but Id want to be positive that the gasket is properly installed first. |
12-24-2021, 09:38 AM | #4 |
Rep 190,750
+1
12-24-2021, 05:58 PM | #5 |
Rep 9
I got new gasket from dealer today and it's still the same. Gap close to the engine is larger than other place.
12-25-2021, 11:07 AM | #7 |
Rep 5,457
Drives: F30
Another (potentially) stupid question…. You dont have the other side hooked up do you? In my experience, its definitely necessary to have that side "free" so you can maneuver the down pipe to get to seat against turbo properly.
The fit is obviously very tight and needs to be just at the right angle to go on fully. |
Lord.Nguyen0.00 |
12-25-2021, 11:08 AM | #8 |
Rep 5,457
Drives: F30
01-10-2022, 06:21 PM | #9 |
Rep 12
Drives: 2015 328i M Sport
I had a similar problem when installing my VRSF downpipe a few weeks ago. Never looked if there was a gap but my vband clamp does not close all the way. When I feel around the clamp it seems properly seated, and it doesn't sound like there is any exhaust leak. Is this going to be a problem?
