11-20-2023, 08:46 PM | #1 |
Rep 12
Advice on replacing 'poverty' buttons with the real thing
Most of us didn’t get an F34 with every option from the factory, leaving us with those blank buttons, or poverty buttons, staring back at us every day. BMW does a good job of hiding missing buttons with trim pieces that make it less obvious that we’re missing options.
The headlight switch has one blank button under the fog light button. And maybe another blank space next to the instrument lighting dimmer dial - can the F34 use a headlight switch with a headlamp range control dial? Under the headlight switch is a row of buttons, mine has 3 but I think it goes up to 5. What are the 5 buttons available there? There are probably some more around the gear selector, does anyone know what buttons are possible there? I just installed a rear fog light button and coded it, it couldn’t have been easier so now I’m looking to do more. Is there any relatively easy way to retrofit other features or options that an F34 might be missing? |
11-20-2023, 09:23 PM | #2 | |||||
Rep 476
2. The blank space next to dimming rotary switch is for headlight levelling rotary slider. US spec cars actually come with vertical adjustment being automatic. No point attempting to have this function in your car. Quote:
Here are the options for center console buttons: https://www.realoem.com/bmw/enUS/sho...diagId=61_2818 F8Xs also have the DIFF button in the same cluster there: Quote:
Like I said, you need to have LED installed to make it look 100% stock: Quote:
For example, I'm looking into wiring the stealth tow bar into my F34 so that I have all the Euro spec features (camera zoom on the ball, turn off the rear PDC when the trailer is plugged in, etc). Here is the link to official list of F34 retrofits: https://www.realoem.com/bmw/enUS/par...MW-340iX&mg=03
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 Last edited by Oksamit78; 11-21-2023 at 07:18 AM.. |
