BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > acceleration hiccups
      07-18-2018, 03:11 PM   #1
cesarortiz23
cesarortiz23's Avatar
Drives: bmw m2 lci
hey you guys so I have been having this problem for some time now but have been ignoring it
I got some other stuff fixed on the car now I want to get this taken car if
So on sport mode I notice that when I do a slightly hard acceleration or hard acceleration I get like misfires it hiccups like even a burble at mid Rpm even tho I'm pressing the gas pedal and some times a big cloud of black smoke
The car is stock only thing is muffler delete and bms intake
you think is a ignition problem
Maybe new coils packs
Sparks was replaced at 55k
Car has 68k now
or is it carbon build up
Maybe I need a walnut shell blasting or ?????
Anyone have any suggestions or opinions
By the way I do not get a check engine light or nothing
bmw m2
      07-19-2018, 07:07 AM   #2
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
First thing you want to do is check for any problem codes with an OBD-II code reader - they don't always produce a check-engine light. Could be a bad coil pack or injector issues - I'd have those checked. Carbon buildup would likely not produce the misfire or black smoke you mentioned.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      07-19-2018, 09:37 AM   #3
Mouse
Drives: 2013F30 335i
^Good advice. I would recommend the same.
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
      07-19-2018, 11:09 AM   #4
Sea-Tac
Sea-Tac's Avatar
Drives: 2108 X3 xDrive30i
Good comments. Good direction to go.
      07-19-2018, 11:11 AM   #5
cesarortiz23
Drives: bmw m2 lci
Ok thanks for the advise
Ima look in to that today
bmw m2
      07-19-2018, 01:26 PM   #6
cesarortiz23
Drives: bmw m2 lci
One thing I forgot t mention is when I do WOT
the car runs great
I only feel this when I have the pedal like 50 to 85%
Once I hit the button on the bottom of the pedal
The car pulls smooth no problem no hiccups
So idk if that helps a bit
bmw m2
      07-19-2018, 01:29 PM   #7
cesarortiz23
Drives: bmw m2 lci
No codes popped up
I just got that checked at a local shop
No codes pop up never has
I been having this issue for quite a while
Even when I had jb4
At first I thought it was jb4 so I removed it
Now I'm stock and I still have the same issue
But never saw a check engine light or a code for this
So what you guys think
Maybe carbon build up ?
bmw m2
      07-19-2018, 01:35 PM   #8
cesarortiz23
Drives: bmw m2 lci
No codes popped up by the way :
bmw m2
      07-19-2018, 02:14 PM   #9
cesarortiz23
Drives: bmw m2 lci
https://www.fcpeuro.com/products/bmw...-12131712219x6
can anybody confirm that these would be the correct ignition coil pack aro buy for my car ?
Or is there another brand that's recommended
I'm thinking of starting off with coil packs and see if that helps my problem
bmw m2
      07-19-2018, 04:17 PM   #10
SteelBlue46
Drives: Alpine White '13 335i XDrive
those coils should work. They look exactly like mine and FCPeuro shows compatible with 335i from 2007-2015
      07-19-2018, 04:18 PM   #11
cesarortiz23
Drives: bmw m2 lci
I think Ima start off by buying the coil packs and see if that helps
bmw m2
      07-19-2018, 09:12 PM   #12
XutvJet
Drives: 2011 Cayman Base, 2016 M235
Put the stock intake back on and see how it drives. I'd do that before throwing new parts at it in hopes of fixing the issue.
Wires1645.50
      07-19-2018, 11:42 PM   #13
cesarortiz23
Drives: bmw m2 lci
It did it before the bms intake aswell
The bms intake I just installed maybe about a week ago
I have been having this issue way before the intake
bmw m2
      07-20-2018, 05:22 AM   #14
BashShah
Drives: 2012 335i Sedan
If you do get a walnut blast done. can you please post picture of what your intakes looked like before the blasting?
I just want to see how much build up there was.
Also you did everything for your problem except Walnut blast, so try it.
or at least have them inspected.
      07-20-2018, 07:51 PM   #15
cesarortiz23
Drives: bmw m2 lci
first Ima do do the plugs since is cheap and easy for me to do my self
Then
Next will be walnut shell blast
bmw m2
      07-20-2018, 08:24 PM   #16
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Sounds kinda like LSPI (low-speed pre-ignition). I only say that because of the black smoke, otherwise I wouldn't have thought of it. This happens in low rpm, but high load conditions, like 50% throttle at 2500-3000 rpms. I'd read about LSPI a bit and see if that sounds like the issue you're having.
      07-20-2018, 08:56 PM   #17
cesarortiz23
Drives: bmw m2 lci
Hey thanks on that input Ima check that out for sure
bmw m2
      07-21-2018, 12:48 AM   #18
cesarortiz23
Drives: bmw m2 lci
So I looked in to it there isn't really much about this happening to bmws :
I did read and saw some videos and they said something about high gear and building up boost on a high gear and having Miss fires
But my car is doing it on 1st 2nd 3rd lol
Is like a constant hiccups all through gears from 1-8
bmw m2
      07-21-2018, 07:31 AM   #19
rjd_F30
rjd_F30's Avatar
Ah gotcha, probably not your culprit then. I haven't heard of it happening to BMWs either but figured it was worth mentioning. Hate to say I don't know what else to suggest, as anything else I'd recommend has already been said. Is your car tuned by the way? If so it could definitely be a tuning issue. I had a sorta similar problem and it was an issue with the tune and was very easy to work out.
      07-22-2018, 10:05 PM   #20
cesarortiz23
Drives: bmw m2 lci
No is not tuned at the moment
When I had jb4
Had the same exact problem
I think is the coil packs
bmw m2
      07-23-2018, 05:22 PM   #21
SoDiezl350
Drives: F30 328i M-Sport EBII
I had a similar problem. Was worse with the piggyback but present even without. Car was otherwise stock. Dealer replaced coils and plugs @ 55k and it went away. 12k miles later and it's back....
      07-23-2018, 06:08 PM   #22
Kraftwerk
Kraftwerk's Avatar
Drives: 2015 335i M Sport
This happened to me at WOT throttle only. It didn't always throw a code. It would throw a code maybe after 3-4 back-to-back WOT runs. Cylinder 6 misfire. Only happened on my BM3 tune though. I ended up replacing the coil packs and everything is fine now.
2015 335i ///M-Sport 8AT | M Performance Exhaust/Brakes/Suspension | BMS CP | BM3 Stage 2 | VRSF FMIC | AR Design DP | AFE Filter | RES Delete | BavAuto Coils | P3 Gauge | xHP Stage 3 |
