03-27-2018, 01:38 PM | #23 |
Rep 647
I did see some on eBay. Assuming knockoffs of course. Pulled the trigger with @mike@xp-h.com last night. I will tackle first nice spring day
BMW DIY Guy3075.00 |
03-27-2018, 02:02 PM | #24 |
OG E46Fanatic
173
Rep 845
All BOV's have fakes, especially the HKS and Greddy ones on Ebay etc etc so you gotta be careful. A lot of times people will upgrade to a better BOV when upping the boost as the stock ones might leak over time and of course some sound awesome too.
03-27-2018, 02:39 PM | #25 | |
3441
Rep 79,211
Enjoy! |
BMW DIY Guy3075.00 JRam243.50 |
03-27-2018, 02:41 PM | #26 | ||
Rep 3,022
Drives: 2019 M2 Competition
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
kevinjt151.50 |
03-27-2018, 02:50 PM | #27 |
A family of bimmers
2747
Rep 7,742
looks like ill be hitting mike up for yet another part soon. may have to stack this with my soon to be purchased bm3 tune.
03-27-2018, 03:38 PM | #28 |
Rep 190,807
Sounds good
04-09-2018, 02:50 PM | #31 |
Rep 3,022
Hey yall.. I have had this part in now for what, a couple of weeks? I am honestly impressed. This is a very subtle component, you aren't going to see a jump in dyno stats or RWP or the like, but I believe very strongly it makes a difference.
Let me see if I can explain it from a butt dyno place.. so accelerating through the gears (6MT here), power and acceleration is rising, clutch in shift and clutch out, and there is that drop off as it then has to catch back up and then accelerate again. Like a rising trend line, drop off to a lower set point then rising again. With this installed, the drop off part of that line in my example, is less, shorter, power returns quicker. That is how it feels at least.. little hard to explain and harder to measure, except maybe if you are a dedicated 1/4 mile kid, and have a ton of runs before this install, and then runs after. I bet you would show faster runs if so.. But I am honestly impressed, and talking with GFB and Brett directly has been awesome!
Drpoomanchu307.50 |
04-10-2018, 11:14 AM | #32 | |
Rep 775
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
05-11-2018, 04:11 PM | #33 |
Rep 3,022
05-15-2018, 12:39 PM | #34 |
Rep 547
So is the sound of the whoosh from the dv quieter than stock now?
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
05-15-2018, 05:54 PM | #35 |
Rep 3,022
Great question and honestly hard to tell.. weather is only starting to get better now in the PacNW, so windows down time. The sound seems slightly softer and longer now, than before, but with my CAI (being really loud), its hard to tell sometimes.
Seba77W401.00 |
07-06-2018, 01:55 PM | #36 |
Rep 603
BMW DIY Guy
Done the GFB DV+ today, and also did the AA FMIC and AA charge pipes. Thanks again for all your videos, that where really helpful for preparing myself. I went to a local shop I know and did it all with the mechanic. My takeaways for the GFB DV+: - preparation is everything. Have a look at the OPs videos, but also at GFB videos, so you know what to look for. - Thankfully I made it in a shop with a vehicle lift! - Car has 55000 km the original valve membrane was still fine - We just released the water pump, but not the holder, and could still manage to access all screws - We used a 1/4" wrench, a cardan joint and some extensions to access to screws. We could also manage to access the top screw this way. Sure a bit tricky, but it worked. - It took us about two hours just for the DV+ install (not rush) - The DV+ change can be done by one person, but sometimes two more hands are just so helpful. (especially for the FMIC and charge pipe change)
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
07-06-2018, 08:47 PM | #37 |
Rep 3,947
Is the original part under the following RealOEM sections?
Engine --> Vacuum Control https://www.realoem.com/bmw/enUS/sho...diagId=11_4472 Or is this something else? |
07-07-2018, 12:57 AM | #38 | |
Rep 603
Diverter Valve https://www.realoem.com/bmw/enUS/sho...diagId=11_6463
Polo088161610.00 |
07-07-2018, 09:02 PM | #39 | |
Rep 3,022
enjoythemusic364.00 |
07-09-2018, 04:48 PM | #40 |
Modder of everything I own
147
Rep 491
I appreciate the videos, I'll be changing mine soon.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
11-25-2018, 04:31 PM | #41 |
Rep 965
Drives: 2016 F36 435x MSport
So i recently purchased a DV+ and spent some time under the car this weekend trying to figure out which way to tackle this on an xdrive. I really couldn't find a way i was confident with. The only way i could find that would make it remotely possible is through the passenger side wheel well after removing the liner... but even that requires some finagling...
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
