BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 New Feature Release - Import OTS Maps, learning experience ***
      05-22-2018, 10:06 AM   #1
proTUNING Freaks's Avatar
3948
Drives: powered by bootmod3
Hey guys,
We've mentioned this feature in the past as something we've been working on adding and it is now available in the editor. OTS maps that we provide as FREE which are basically OEM like calibration data can now be used as really great reference points if you have a desire to learn how to tune on this platform.
In the S55 case you can import the GTS, CS and CSL OTS maps. On the N55 EWG you'll have access to the M2 map and on the S63tu to the Comp Package (600hp) map.
As an example, you can open your Stock Tune first in the editor, do "Save As" to make a copy of it for custom tuning reasons (stock tune itself cannot be edited). Once you create a map, name it as you wish and proceed to the editor to import one of these OTS maps that you find most appropriate/intriguing and go from there. Editor will highlight tables changed in 'red' between your stock and the imported map. If you click on any given 'red' table you can hover on and off the button called 'Original' and see changes in your original (stock) map and if you hover off you'll see the imported changes in bold.
Let us know if any questions at all
Here's a quick vid we put together to demonstrate how its done:
bkdore96.00
      05-23-2018, 07:48 AM   #2
ceedawg
ceedawg's Avatar
457
Drives: 2k15 335i xdrive MSport 6spd
Thanks for posting. Looks very good
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      05-23-2018, 05:45 PM   #3
mike@x-ph.com
mike@x-ph.com's Avatar
September SALE||https://x-ph.com/sale/
Phone number 702-494-9435
      05-24-2018, 08:51 AM   #4
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Awesome!!
Mike
bm3, bootmod3
