03-22-2021, 02:22 PM | #1 |
Rep 13
Battery Replacement and Coding
Hi folks,
Looking for a bit of advice. My wife’s friend has an F30 diesel that needs a new battery. It’s currently got an AGM 90Ah/900A/900CCA, the aftermarket batteries I can get are 95Ah/850A or an OEM which is a superseded one, though I’m unsure of the specs. The parts supplier I use for the aftermarket one said he thinks the genuine will be 92Ah, though it’s probably not that important. I’ve researched the coding required for a battery change, and it looks pretty straight forward. Firstly registering that the battery has been changed, looks like either INPA or ISTA will do. Secondly, changing the battery capacity in NCSExpert, again, pretty straight forward. I’ve got an E91 and have done various bits of coding on it, so familiar with the process. My question is relating to the battery capacity, as I’ve not had the car to plug into, I’m going from what I’ve seen online, and it doesn’t look like 95Ah is an option in NCSDummy, so does that mean if I manually enter 95Ah AGM in the .man file, it’ll throw an error? In which case, should I leave the capacity as it is at 90? If this is in the wrong section, please let me know. Thanks in advance! |
03-22-2021, 02:55 PM | #2 |
Rep 16,088
You want to code it as close as possible to the actual, but don't be concerned if the software doesn't allow it to be exact. Say the only options are 90Ah and 105Ah and you've got a 95Ah battery. Leave it at 90Ah, as at 105Ah you'd overcharge.
02-28-2022, 03:23 AM | #5 |
Rep 79
Hi i will need a battery replacement as well.
My quick question: will registration work witn an ENET cable and ista + on f31 facelift? Thx! (I have succesfully coded some small stuff with esys and read/cleared out fault memory with ista + with that enet cable) |
02-28-2022, 03:33 AM | #6 |
Rep 525
Yes without problem
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
03-01-2022, 01:52 PM | #7 | |
Rep 79
08-03-2022, 12:06 PM | #8 | |
Rep 312
Battery change => erase coding?
I've hunted around here without quite finding my answer. Forgive my poor researching skills. I've got to replace my 2015 F30 OEM battery. I can code the car for the new battery but wondered if when I disconnect the old battery, will I erase the other coding that's been done on the car? I wouldn't _think_ so but it would be a pain to discover otherwise after putting in the new battery.
10-04-2022, 02:52 PM | #10 |
Rep 3,870
answer is ambiguous....
Is it: "No coding will stay" = None of the code will stay, it will all be gone... ? OR "No, Coding will stay" another question: anyone considered putting / replacing with lithium battery ?
Tommo355.00 |
01-09-2023, 09:43 PM | #13 |
Rep 664
Drives: 2013 BMW 335i
did you ever find an answer to the lithium battery? was thinking of going with AntiGravity battery
03-07-2024, 09:55 AM | #15 | |
Rep 184
Many people put spoilers on their car or change wheels to fit bigger tyres, but none of those mods are cost effective. |
03-07-2024, 11:54 AM | #16 |
Rep 16,088
People will want lithium because they've heard that it's good technology. They don't work any better. Of course that won't stop people from using them, people installing mods that don't work better than stock is what keeps the mod manufacturers in business.
