03-03-2018, 06:14 PM | #1 |
Rep 1,805
Ceramic controls retrofit - success
Ceramic controls retrofit...finally done
Plug and play, everything works as it should.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
03-04-2018, 12:54 PM | #2 |
Rep 1,805
Now to the buttons. Prob will have to buy a complete 5 7 or x5 climate control panel.
03-04-2018, 01:32 PM | #3 |
Rep 92
Nice! Where'd you order this from? I may want to get.
F30 328i Mineral Grey Metallic, M Perf Kit, M Perf Exhaust, Matte Black Kidney Grills, H&R Sport Springs, 19" Velgen VMB5 Rims.
03-04-2018, 02:59 PM | #4 |
Yoda of mods
1676
Rep 3,006
Drives: X5 RWD
Exactly ^. Looks nice and where from?
03-04-2018, 07:20 PM | #5 |
Rep 61
I love this. I have the "ceramic" look panels, not the silver or carbon fiber. So the ceramic controls would totally match my current interior panels
03-04-2018, 07:53 PM | #6 |
Rep 5,776
Looks pretty good! And I like Diet Dr. Pepper as well. Where did you buy it and how hard was the install.
Last car: 2011 335i Msport. JB4. Vrsf CP |
PabloK597.00 |
03-04-2018, 08:15 PM | #7 |
Rep 605
Nice! any pics from a bit further out?
I have that same Diet Dr pepper, I can confirm that the Diet Dr Pepper is a direct install, easy diy. Guaranteed to make you happy. 5hp increase to your daily life. |
03-04-2018, 09:00 PM | #8 | |
Rep 10,473
Did you just move the ceramic cover onto your F30 shifter or totally take part the F10 Shifter and install that in the F30 base? Ceramic look panels |
03-04-2018, 09:19 PM | #9 | |
Rep 1,805
Part # 61319252141 I found one on eBay dirt cheap. cover pops off, 1 screw holds everything together. 5min install. iDrive knob Found one used on eBay, got lucky as it was compatible with evertyhing. Forgot to take a pic of the part #. -Trim justs pops off, 1 cable to the unit and 3 screws that attach it to the trim. 5 min install Volume/climate buttons will be much more involved. Not even sure if possible.. http://f10.5post.com/forums/showthread.php?t=1400128 I'll give it a try later on this spring...
03-04-2018, 09:21 PM | #10 | |
Rep 1,805
yea i'll get some more pics tonight.
03-04-2018, 09:32 PM | #11 | |
Rep 10,473
I told you and others in other threads everything was compatible, so that’s no surprise ....the complexity comes in if you do the full F10 shifter retrofit. Glad it all worked out for you. |
PabloK597.00 |
03-04-2018, 10:15 PM | #12 | ||
Rep 1,805
I just swapped the ceramic portion to avoid any comparability issues. I remember reading your posts.., but my memory is horrible, I thought the main compatibility issue was with the iDribe knob.
03-04-2018, 10:17 PM | #13 |
Rep 1,805
More pics....
I need to swap out the silver center piece around the base of the shifter to clean it up.
AndrewC198910932.50 |
03-04-2018, 10:17 PM | #14 |
Rep 10,473
If you plug in the F10 shifter (it won’t fit in the f30 shifter slot so do not attempt to bolt in), you can see it works fine with no compatibility issues.
03-04-2018, 10:51 PM | #15 |
Rep 10,473
Will be interesting to see if you can find that piece that matches the OEM finish, weave and direction of your other OEM Parts, especially as they will be side by side in center console.
03-04-2018, 11:14 PM | #16 |
Rep 1,805
After further thought, I'm just going to wrap that silver center surround.
You can get any color/shade/finish on the face of the earth. While I like CF bits, it's a fine line and too much makes the interior look gaudy. Below is just a random google image that I spent 10 seconds searching for, but I'm confident my shop can match it perfectly. More to come..
03-05-2018, 02:45 AM | #18 | ||
No 55mph
1622
Rep 8,476
I did the ceramic iDrive controller swap some time ago, was also thinking about swapping out the knobs. Read thru the exact same thread you reference - got with the OP of that thread with some questions. His last reply was: Quote:
PabloK597.00 |
03-05-2018, 02:53 AM | #19 |
No 55mph
1622
Rep 8,476
Also, for anyone looking to pick up the ceramic iDrive controller - this is link to forum member selling them:
http://f30.bimmerpost.com/forums/sho....php?t=1461594 I got mine from him - quik shipping, unit was in perfect shape, PnP everthing is functional. His price is good
03-05-2018, 02:57 AM | #20 | |
Rep 1,805
03-05-2018, 11:17 AM | #21 | |
Rep 322
PabloK597.00 |
03-05-2018, 11:19 AM | #22 | ||
Rep 1,805
Thanks brother
