BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > piecing together a m sport brake kit. need help with some bolts
      05-25-2019, 02:18 PM   #23
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
Originally Posted by M4_GTS View Post
Originally Posted by Logicoeur View Post
Your existing bolts should work fine. Youll have to go to realoem to get the specific part numbers.
that's the worst advise. a lot of bmw bolts are stretch bolts that 1 time use only.
The bolts in question are not stretch bolts.
      05-25-2019, 04:05 PM   #24
M4_GTS
Hong Kong
1153
Drives: M4 GTS
please look up the rear caliper bolts in TIS because they are stretch bolts. The M Performance brake kit comes with all new bolts because BMW actually says that brake caliper bolts are "one time use".
you clearly shouldn't be giving advise...
Originally Posted by FMLYSDN View Post
You're a dick. Oops. Did I just say that?
      05-25-2019, 04:08 PM   #25
Logicoeur
Logicoeur's Avatar
993
Searching the part numbers for front and rear doesn't return anything described as stretch bolts. Can you show us where they are listed as stretch and one time only, or you just going to troll and use emojis?
      05-25-2019, 04:12 PM   #26
M4_GTS
Hong Kong
1153
Drives: M4 GTS
Now can you please not give out anymore incorrect info here? Seriously, I sure hope you're not wrenching on your own cars or any cars.
Torque specs and hardware that needs to be replaced:
Front brakes https://www.newtis.info/tisv2/a/en/f...rakes/GfqyNpyB
Rear brakes https://www.newtis.info/tisv2/a/en/f...rakes/GfyH0Hrd
2AZ Caliper carrier to wheel carrier Jointing torque 50 Nm Angle of rotation 60° Replace screws with a "!" means its a must and a important warning.
      05-25-2019, 04:28 PM   #27
Logicoeur
Logicoeur's Avatar
993
Oh well, they recommend replacing them. You get a gold star. Dickhead.
REALoem doesn't show anything like this, and the part numbers are listed online as hex bolts, everywhere. Personally, I have never had a problem with reusing stretch bolts on any of my cars in the past.
      05-25-2019, 04:42 PM   #28
M4_GTS
Hong Kong
1153
Drives: M4 GTS
Oh well, looks like you need to do some reading and understand why its not "OK: to reuse stretch bolts. http://repair.alldata.com/online2hel...be_re-used.htm
Gets proven wrong and calls the other person that's able to provide the correct info a "dickhead". It's ppl like you why the world is going ass backwards. Learn from your mistakes and accept responsibility is how you gain more knowledge. Basic life lesson.
      05-25-2019, 04:55 PM   #29
Logicoeur
Logicoeur's Avatar
993
Because you provided the information like a dickhead. I don't mind being proven wrong, hence me asking you for the information in stead of your snark, and unhelpful remarks. Dickhead.
People like YOU ruin the community because it makes others afraid to share in fear of being ridiculed by idiots like you.
Have a nice life with your head that is shaped like a phallus.
      05-25-2019, 05:04 PM   #30
M4_GTS
Hong Kong
1153
Drives: M4 GTS
Sometimes its better not to share if you just don't know.
People like you ruin the community because you're giving wrong advise and info when you are clearly just "guessing" and have no clue. This is especially critical when its the brakes which can easily kill someone when shit goes wrong.
Name calling like you're still in elementary school yeah? sad...
      05-25-2019, 05:39 PM   #31
Logicoeur
Logicoeur's Avatar
993
People can be wrong. I can be wrong, but how you handle it is what matters. I did research before I said he could reuse the bolts. Searched the part numbers and didn't find anything. Then I ask you to post it, but you were still a dickhead about it. So be it, be a dickhead all your life. Fine with me.
      05-26-2019, 03:55 AM   #32
jdgay22
Drives: 428i f33 m sport convertible
so if the answer is i do need replace the screws and bolts. do yal have the part # .. thx in advance
M4_GTS1152.50
      05-26-2019, 11:17 AM   #33
M4_GTS
Hong Kong
1153
Drives: M4 GTS
Let this dickhead or phallus shaped head (as described by @Logicoeur) help you out here. As per BMW repair manual, these are the recommended hardware to replace.
Replace 5, 7 (14 only if you're changing the heat shield)
http://www.realoem.com/bmw/enUS/show...diagId=34_2351
Replace 5, 7 (14, 15 only if you're changing the heat shields)
http://www.realoem.com/bmw/enUS/show...diagId=34_2313
      05-30-2019, 07:36 PM   #34
jdgay22
so one last question.. i see there number of bolts listed on the links you gave me . so is that per caliper or for a set of 4.. cause if its per caliper it will add up to way more bolts then the picture of the m performance brake kit
https://f30.bimmerpost.com/forums/mu...tor/attach.gif
      05-31-2019, 09:00 AM   #35
M4_GTS
Hong Kong
1153
Drives: M4 GTS
qty neeed for the car.
      01-17-2020, 07:30 PM   #36
jdgay22
i Have a f33 with the msport kit p337a . i found with this my rear dust shield will not have to be replaced. the question is since my front rotor is 330mm and the m sport brakes kit is 340mm would that dust shield fit or do i need two new ones
      11-27-2021, 03:31 AM   #37
Gidimba
Drives: BMW 320i (F30) 11/2013
From standard to brembo grey
Hi,
So I have the standard one piston breaks and I have bought the front 4pistons grey brembo breaks of a 335i,
Do I need to replace also the dust shield?
2014 F30 320i
H
