BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Has anyone tried this on their N57, adjusting the EGR fresh air ratio?
      01-01-2018, 03:20 AM   #1
Len_Beach
Drives: 435d
I'm intrigued as to whether this will work on the 30/35d as it did on my E90.
http://www.e90post.com/forums/showthread.php?t=1296190
      02-26-2018, 06:54 AM   #2
Sullym6
Drives: Not got it yet
Is there a guide on how to do this?
      02-28-2018, 10:55 AM   #3
Len_Beach
Drives: 435d
There's a rough guide at the bottom of the link below.
What model do you have?
http://www.bimmerfest.com/forums/sho.../topics/835572
      02-28-2018, 01:49 PM   #4
Sullym6
Thanks len
I have 2014 335d, did this on my previous vag cars and always felt a decent improvement
Will report back once I have had a play
Sully
      02-28-2018, 03:48 PM   #5
Len_Beach
Drives: 435d
Thanks len
Sully
Good man
      03-02-2018, 03:51 PM   #6
Sullym6
Thought I would have a go tonight and there is no egr adjustments option under service functions. Any tips welcome
      03-06-2018, 03:52 PM   #7
Sullym6
I have just tried with ista 4.09 and still I do t see egr adjustment under service functions.
Does anyone have any ideas as just spent 2 evenings download and setting up a newer version of ista only to find the same issue
      12-08-2018, 05:07 AM   #8
Len_Beach
Drives: 435d
Was there any progress with this?
This made a positive difference to my 330d so keen to do the same on my 435d.
      12-08-2018, 12:23 PM   #9
Watsey
Drives: F31 330D sDrive M Sport
I had the EGR coded fully closed as part of the remap. The engine (30d) is more responsive, revs smoother, has less diesel rattle, and fuel economy improved by around 4mpg.
I appreciate the case for EGR but the effects on driveability and fuel economy outweigh that IMO.
      12-08-2018, 01:02 PM   #10
Enabled
Drives: 328xd Wagon, M2 Competition
If you had a remap, you can't simply associate EGR closure with all those effects. Remaps change a lot of things, depending on the skill of the tuner.
Leaving everything else stock, EGR operational will get better fuel efficiency, as long as intake is clear. EGR off alone with no other changes will get worse fuel mileage.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      12-08-2018, 05:51 PM   #11
Len_Beach
Drives: 435d
I was the original poster of that thread and I saw around 4mpg improvement on my E90 330d N57 by reducing the EGR opening.
      12-09-2018, 11:06 AM   #12
Enabled
That's really interesting, because when turned off from tune (on 328d) the results are different. There is more turbo compensation, which results in the turbo "blocking" free exhaust flow. Of course there are many different ways to turn it off in the tune as well.
If I remember correctly, the newer ISTAs removed that feature, since all the emissions scandals.
Tool32 should still be able to do it still.
Others:
