BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Air filter change?
      11-01-2018, 12:10 PM   #1
theplasticbling
Drives: 328d xdrive
Air filter change?
Hey everybody, I'm getting ready to change my oil and do an air filter change as well. I ordered a K&N drop in so I can just clean it instead of ordering a new filter every time I need one. I do have one question though: What's the gray pad that's on the bottom of the stock air filter? I haven't seen this on any of my other cars. I can post a picture if you'd like. Should I clean this/put this in with the new air filter or should the K&N come with one or do I not need it at all? Thanks guys.
      11-01-2018, 12:11 PM   #2
bimmer456
Drives: 340i
Post a pic.
      11-01-2018, 12:14 PM   #3
Enabled
Drives: 328xd Wagon
Ehh, K&N lets in too much dust. Look through the filter into sunlight, and you will see how inconsistent the filter media is.
Your turbo blades will appreciate not being sandblasted.
Stock paper filters are cheap and effective.
The gray pad is an additional filter media.
-2014 328d Wagon 2WD, 8HP flash, self-tuned, 265hp/430ft-lbs.
Others
-E36 328is ~210-220whp: Lots of Mods. 2000 Z3 Roady. 2003 VW Jetta TDI Manual 47-50mpg Modded. S52 Estoril Z3M Coupe.
      11-01-2018, 12:36 PM   #4
theplasticbling
Drives: 328d xdrive
Lol well the k&n is already in, I'm in Florida and with higher humidities there isn't really any dust in the air. I'll take my chances. I've always had good luck with k&n filters and had a bsr in my Saab that was wonderful.
https://photos.app.goo.gl/V3wty7E64hhTAEyv9
As for the gray padding, here's a picture. is that something I should purchase as well or am I fine without it?
sspade978.50
      11-01-2018, 12:40 PM   #5
sspade
Drives: F30
2016 BMW 320i  [0.00]
2014 BMW 328i  [5.00]
That looks like an extra piece of filter media of sorts?
Cant be good for airflow.
You'll be fine with the K&N as long as you dont go off roading. I just had a Blackstone analysis done while running a K&N filter and passed with flying colors. I posted the results on this forum if you care to see them.
      11-01-2018, 04:52 PM   #6
theplasticbling
Drives: 328d xdrive
Many thanks! I'll check it out.
      11-01-2018, 07:00 PM   #7
FaRKle!
Drives: '17 328d Sport Wagon
I've seen the extra gray material referred to as a snow filter.
      11-03-2018, 09:21 PM   #8
theplasticbling
Drives: 328d xdrive
Interesting. The only use I see for this materiel is to achieve less airflow! Going to be running the car without it.
      11-11-2018, 12:56 PM   #9
BigJack75
BigJack75's Avatar
Drives: M5 Dream Car
The extra filter material looks just like a home ac filter you can cut to fit. Not sure why everyone is ASSuming it will impede air flow. I don't don't think it will. As a test you can place it over your mouth and breath. I'm sure you will not suffocate. The previous owner must have added this. I've never seen one on a filter before.
435i GC
      11-11-2018, 01:55 PM   #10
Enabled
Drives: 328xd Wagon
It won't impede flow when it's all fresh and new.
Then again, even if you do improve air capacity, it wouldn't make a difference at all in a diesel.
The diesel ecu will not add additional fuel (not on fixed afr) when there is more air, so no additional power is to be gained.
Others
      12-11-2018, 07:10 AM   #11
movietub
Drives: 330d M-Sport Touring, Black.
Did the K&N lead to better induction sound in the cabin?
I quite like the idea if so..
      12-11-2018, 07:33 AM   #12
sspade
Drives: F30
Yes... you will get a bit more intake sucking sound with an aftermarket filter.
      12-16-2018, 10:19 AM   #13
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Indeed. People just don't understand that the stock filter and intake provide more air than the stock engine can ingest.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
