05-16-2018, 07:43 AM | #1 |
Rep 460
Sooty exhaust
So since I've had my 335d I've never seen any soot or blackening around the exhaust and since the remap a few weeks ago much has stayed the same. However I've just been out for a lunchtime blast with a colleague, engaged full attack mode, Sport+ and stick to the left. On parking up at the office I noticed that the exhausts are now looking pretty mucky with soot which wasn't there prior to the 10 mile lunchtime drive.
Is this something to worry about? Or just maybe the exhaust having a good clear out after the blast? |
05-16-2018, 07:59 AM | #2 |
Rep 1,795
I'm not sure what other diesel owners consider bad but I get that after a little journey into the office. If I drive it for a tank on "attack mode" they'll look like someone has spilt a pot of black paint everywhere
James-335dx238.50 David Kunitz863.00 |
05-16-2018, 08:14 AM | #3 |
Rep 8,647
My exhausts are definitely sootier post-remap, and certainly sootier than yours.
05-16-2018, 08:29 AM | #4 |
Rep 460
Okay, thanks both. Might not be anything to worry about then by the sounds of it. Someone in the office mentioned that the DPF has a purge every so often so might just be that? Possibly encouraged by the thorough thrashing?
05-16-2018, 09:56 AM | #5 |
King of the North (living in the east...)
1043
Rep 2,168
Dam that's a dirty diesel. I'd scrap it immediately and get a 440i...
2021 M340i in mineral white, options galore
Previously 2018 440i GC in MG 2015 330D F30 MSport EBII 2012 Alfa Guilietta 2.0d Veloce 2009 Fiat bravo sport 2000 ST Mondeo |
James-335dx238.50 sahajesh2304.00 |
05-16-2018, 10:15 AM | #6 |
Rep 19,982
Same here. Still, better than the old E46 days and the shame of the down-turned pipes.
05-16-2018, 10:28 AM | #7 |
Rep 7,000
Pipes are always really clean even after a blast. If I wipe my finger inside then there is only a very slight amount of dust.
Never ever is it that bad. I use Millers Eco Max additive which may help?? Black deposits are not ideal as it possibly shows the DPF is being overloaded and cant manage the amount of soot, I am not an expert though Car has been mapped by Evolve |
05-16-2018, 10:37 AM | #8 |
Rep 460
05-16-2018, 10:41 AM | #9 | |
Rep 460
Any experience of this apparent DPF regeneration? |
05-16-2018, 10:42 AM | #10 | |
Rep 7,000
What figures did the map take the car to? I am sure its nothing to worry about, just give the pipes a good clean and monitor it |
05-16-2018, 11:18 AM | #11 | |
Rep 460
412BHP and 730Nm so it isn't slow now! |
JLR19691834.00 |
05-16-2018, 03:31 PM | #12 |
Rep 541
When I had the tuning box on I had soot in the pipes. After my remap there is still some soot, but less, even without back box. The main thing is I dont get puffs of smoke coming out of the tailpipes on acceleration like I did with my E92 335d.
I dont think the amount I have or yours is anything to worry about. |
James-335dx238.50 |
05-16-2018, 04:44 PM | #13 |
Rep 637
Soot in pipes not a healthy sign me thinks. But mapping will increase the risk of soot. Keep an eye on the situation. Drive normally and see if the problem reoccurs. If it does then you may want your mappers to dial back on the map. The last thing you want is a knackered dpf.
Ps doesn't look overly sooty. |
James-335dx238.50 |
05-16-2018, 04:47 PM | #14 |
Rep 637
pushing over 400. That's pretty impressive. Nearly 30% increase. Pretty aggressive.
James-335dx238.50 |
05-17-2018, 02:22 AM | #15 | ||
Rep 460
I know, not bad for a stage 1, a few on here have questioned the figures suggesting the dyno is off but the stock figure seems realistic to me so not sure how it would be off after the map? |
05-17-2018, 02:29 AM | #16 |
Rep 710
I really wouldn't worry. My 435d has been remapped and I noticed after a dpf regen that there was a tiny amount of soot. When I had my 318d the exhaust was far more sooty than the 435d.
James-335dx238.50 |
05-17-2018, 05:38 PM | #17 |
Rep 45
That’s not bad at all. The reality is they will let off a light dusting of soot under load. So little you’d never tell or notice it looking out your rear view mirror but you probably would if you let someone else drive it as you drove behind it in another car or observed it on the dyno.
Nothing to worry about, I’ve seen much worse. The DPF will also automatically regenerate itself every 300-400 miles or so and burn off all soot in the dpf filter which will in turn likely soot up your tips too... |
James-335dx238.50 |
05-20-2018, 04:13 AM | #19 |
Rep 9,708
Your remap has most probably pushed fuelling above the 'smoke line' by some margin.
The dpf is not able to process the soot / burn off the excess fuel as well as a standard car, so you will have smoke and soot getting through. Make sure you change engine oil more frequently. That excess diesel will be watering down your oil too. |
JLR19691834.00 James-335dx238.50 |
05-20-2018, 11:50 AM | #20 | |
Rep 7,000
05-20-2018, 02:26 PM | #21 | ||
Rep 9,708
James-335dx238.50 |
05-22-2018, 10:50 AM | #22 | |
Rep 460
