03-05-2024, 08:03 AM | #1 |
Rep 23
Will 430D lowering springs work with a 420D?
Hey guys,
Someone local to me is selling a set of F32 lowering springs. They are off his car (430D) and have only covered 1000 miles. I drive a 420D and he assured me they will fit but I'm not sure as the 6 cyl engine will weigh more than the 4 cyl which will have a bearing on suspension so thought I'd ask here. Both are non Xdrive. Cheers. Last edited by Dufftx; 03-05-2024 at 08:12 AM.. |
03-05-2024, 08:18 AM | #2 |
2317
Rep 2,497
IIRC they'd work; but the spring rates will be for the heavier engine and won't lower as much; but they'd still lower your car
03-05-2024, 08:33 AM | #3 |
Rep 23
Cheers for the reply! They're 30mm lowering springs which I believe will really only lower 20mm if the car has factory M suspension already, and if they won't even lower a 420D 20mm I guess there's no real point in getting them haha.
03-06-2024, 03:13 AM | #5 | |
Rep 3,266
Best you buy the correct product for the application and fit once, job done. Alought likely more expensive to do, it will save you money in the end. |
03-06-2024, 05:47 AM | #7 | |
2317
Rep 2,497
Eibach's are much better suited Exactly what I've just had fitted, alongside all new Bilstein B4S shocks and every arm/link to my F31 The car drives & handles superbly now and takes the rough roads local to me much, much better
03-06-2024, 05:57 AM | #8 | |
Rep 1,467
Having said that, it depends on the brand of spring as some are generic for a range of (non M) engine sizes and only stiffen up the rates within the tolerance window of all the damper flavours available. |
03-06-2024, 07:45 AM | #9 | |
Rep 23
03-06-2024, 08:20 AM | #10 |
Rep 1,467
Pro (black). Don't go for the sport (red) springs.
Use the dampers recommended on Bilstein's catalogue, which if M sport will be "B4 - for M technology suspension". That is what he meant by B4 'S' dampers, which are mild upgrade over stock, in the order of ~ 10% stiffer. |
danb19792316.50 |
03-06-2024, 09:02 AM | #11 | |
Rep 23
03-06-2024, 09:31 AM | #12 | |
2317
Rep 2,497
Bilstein B4S shocks with all new Sachs top mounts all round (and all new OEM BMW rubber bits/bump stops/dust boots/gaskets etc) and Eibach pro it springs Sportline springs (the red ones) lower far too much and you need B8s for those; they'll kill standard dampers or B4's etc But the B4S shocks and Eibach pro-kit springs work superbly and I'll always highly recommend them It's all in my project thread which is linked in my sig below
