03-06-2024, 03:52 AM | #1 |
Rep 25
F30 Fault codes??
Hi everyone I own a 2012 328i and getting the following codes under central gateway module. Have tried to look them up on the fault codes site but there isn’t much information. I’ve not really noticed any physical issue but has anyone had these codes before?
1006FF FlexRay Logger error memory entry 1011FF Logger error memory entry for other ZGW components 101008 Non-resolvable ambiguous routing - SG not in the SVT target table 100104 HW Weckgrund ZGW 100001 VcmResultSvtCheck - identity check: Differences between the SVT actual and SVT target have been recognized. 100203 DM software error info warning 100204 Message monitoring: no system context signal |
03-06-2024, 06:02 AM | #2 |
Rep 1,467
Was that a Bimmerlink code in "Info memory"
If so, ignore it. You can sometimes get FlexRay codes when scanning with the engine off. ISTA does it as well sometimes. You only need to concern yourself with faults in "Permanent errors" FlexRay is the optical bus and can be fickle with battery voltages and response times when communicating with other modules. |
kubehz1.50 |
