08-20-2021, 04:08 PM | #1 |
Rep 87
F30 Rear Trunk light no power?
Hey, Ive been using a set of Mashimarho GTS lights, worked beautifully, had a problem where my trunk light passenger side fitment was off and overtime got bad, then slowly the light itself went out.
Come today I got the new one in, but now the power still didn’t light up the bottom row of the strip ( GTS design scale thingy) doesn’t light up but my brake and indicator light work. Narrowed the issue down to the connector that plugs into the trunk light, doesn’t give power, used the driver side connector to power the passenger side and it worked. So how do I go about replacing this wire ? or do i have to replace the entire harness…? From the picture, the left side set of wires are the ones not working. |
08-21-2021, 09:40 AM | #2 | |
Rep 208
08-22-2021, 05:53 AM | #4 |
Rep 208
Yeah I'd be a bit worried if there was no power coming down that wire could be a pain trying to track that back to find a break or worse no power being supplied from the module. If that's the case may be an easier option to just run a wire from the other side tail light
08-22-2021, 08:17 AM | #5 |
Rep 298
I am not sure if it is same with F series but E series light module would stop supplying voltage to a certain bulb after a number failures, and need to be reset before it starts working again. Common issue if you first have wires broken from the hinge area and have them like that for a while, then fix the wiring and wonder why the lights are still not working.
08-22-2021, 12:00 PM | #6 | |
Rep 87
Ahh I was not aware of that, I acutally took off the broken connector and directly spliced the wires together, cus I didn't know what to try, how does one try resetting it? |
08-23-2021, 03:17 PM | #7 |
Rep 298
With E series it is usually done with Tool32 software, I don't know if F series modules have similar counters. Google FRM short circuit reset. Anyway if this is your issue you should have stored faults about short circuit, if not then it's something else.
08-30-2021, 01:16 PM | #8 | |
Rep 87
Does that mean I have to reset it ? |
