06-24-2019, 11:44 PM | #45 | |
Rep 1,045
Mods: Dinan Tuned, Intake, Catless DP
06-25-2019, 12:19 AM | #46 |
Rep 776
06-25-2019, 09:39 AM | #47 | |
Rep 1,610
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) Last edited by adhrp; 06-25-2019 at 09:44 AM.. |
The Kurgan28.00 |
06-25-2019, 12:05 PM | #48 | |
Rep 82
Drives: 2012 BMW 328i Luxury Line RWD
Ditto on routine maintenance. I do what is required when it's required. As for the mirror motor and horns... it may be a coincidence, but I tend to clean my car alot in the winter to keep the salt off of things. I am thinking water and ice were the culprit. No matter, the horns were replaced under warranty, and are now back to the usual wimpy OEM sound--this car needs a Stebel Nautilus dual horn The driver's side mirror was replaced as a complete unit (can't just replace the motor), unfortunately out of pocket (a few months out of warranty!). The gas tank vent valve started acting up in the dead of winter in 2017, and has triggered intermittent faults (CEL) for 2 years. Finally, I gave in and replaced the darn thing. It was a relatively cheap fix. Smoother idle at start-up, and better gas mileage. Gas mileage is amazing on this car. I also plan to keep my car for a few more years, and have already booked her in to have the front bumper repainted and chrome trim pieces replaced. Other than that cosmetic wear issue, the only real complaint I have is that the air conditioning is never fully cold, just cool--been like that for years. I will likely get that serviced soon as well. All in all, it owes me nothing and has been bullet proof. The motor is fantastic and overall build quality is very good. I have no worries about timing chain failure. The 2012's seem to be particularly trouble free. What I like the best is that she has ZERO rust. All my previous cars: Toyota, Hyundai(!), Ford and Dodge were rust buckets by year 4 or 5. |
06-25-2019, 12:29 PM | #49 | |
Rep 1,610
Re: rust - I do not wash my car much in the winters because I know that it will be once again be coated with salt within a couple of days. Even then, it is rust-free after 7 years of plying the snow belt. I think BMWs are just built very well using top-grade materials and processes. That said, my Toyota Highlander of the same age and having lived in the same snowy/salty environment shows no signs of rust either.
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
FastActionJax407.00 |
06-25-2019, 07:34 PM | #50 |
Rep 126
134k on 2012 F30 RWD
Getting front struts and rear shocks replaced with bilstein tourings Alignment Spark plugs Trans service And brake flush. |
The Kurgan28.00 Kingpin4386.50 |
06-26-2019, 05:39 AM | #51 |
Rep 68
63k 2014 F30 335xi
Got it at 44k Only thing I’ve had to replace is water vent hose coming from coolant tank. Regular maintenance, 6-7k oil changes with Liquid Moly. Coolant flush completed when I changed hose Next oil change is in about 3000 miles, planned on servicing transmission and changing spark plugs. (Maybe coil packs) Will inspect brakes too, I get a lot of dust with the OEM pads but they still got a lot of meat on them so I might just deal with it until it’s time to change them. |
06-26-2019, 08:45 AM | #52 | |
Rep 139
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150 2021 RnineT 2022 K1600B |
NYOreo2320.50 |
06-26-2019, 08:57 AM | #53 | |
Rep 68
About 10k miles ago, I actually had cylinder 2 misfire. I had a close mechanic friend of mine say it was possibly bad gas. We put fuel cleaner in it and I've never had the issue come up again. (I also never went to that gas station where I got my fuel from last, It was a place I've never gone too). I think that moment has had me thinking of changing them......... |
06-26-2019, 09:17 AM | #54 |
Go Fast Dont Die!
407
Rep 472
Drives: '12 328i Sport 6MT
I have an N20 6MT with 80k and FBO stage 2 with boost dropped to 18psi instead of the 22psi it was trying to push, motor is seems strong although I believe I'll be replacing the turbo here pretty soon because It will idle rough on start up and die sometimes, then on restart its fine but boost is certainly laggy'er than it should be and I am burning some oil. idk for sure though because I havent investigated it thoroughly but I do live in a very hot environment. we will see, I have contemplated getting rid of the car because all the N20 hate makes me nervous but I decided to ride it out because I do love the car.
BootMod3 stage 2 93 octane AGG| K&N Drop In| Turner Motorsports Intercooler| BMS Catchcan| FTP Chargepipe & TIC| MST Turbo Intake Pipe| CW Catless Downpipe| BAV Coils| KW DDC Coilovers| Active Autowerke Exhaust| CF Mirrors| CF Spoiler| Rohana RFX11| Black Painted Roof| @instagram.com/fastactionjax/
@youtube.com/fastactionjax/ |
06-26-2019, 09:32 AM | #55 | |
Go Fast Dont Die!
407
Rep 472
yep
06-26-2019, 09:53 AM | #56 | |
Rep 82
As for the timing chain, don't sweat it. It can impact any car, model or year. Prolonged oil changes, as originally recommended by BMW (every 20,000 km !) can lead to reduced effectiveness of the oil. Less lubrication, due to degraded oil, will eventually cause wear to the various timing chain components, and this in turn can cause timing chains (and other chains) to elongate to the point of possibly skipping a few teeth (!) and may cause catastrophic engine damage. The "new" 2015+ timing chain guides (white) and original (late 2011-13/14) timing chain guides (orange) are probably made of the same material! The key, I believe, is 7000 (or less) mile oil change intervals to keep timing chains properly lubricated (and prevent sludge build-up). Heat will make ALL plastic timing chain guides brittle over time. Just throw in the possibility that there was a bad batch of timing chain guides and/or timing chains (impossible to prove) from the equipment suppliers and you have a more complicated problem on your hands. An elongated timing chain and a brittle timing chain guide is a recipe for disaster. I absolutely guarantee that we will start to see higher mileage 2015+ F3x's exhibit elongated timing chains and some will also experience catastrophic engine damage as a result. There may be less cases, as most owners are now aware not to stretch oil change intervals as originally recommended by BMW in 2012 and 2013 (!). Also, using the correct/recommended oil and correct AMOUNT of oil is also key! You would not believe the number of boneheads (individuals and shops) out there that are negligent on this regard! It is truly mind boggling. It just didn't help that BMW recommended ridiculous oil change intervals. This famous class action lawsuit regarding F30 timing chains is based not on the timing chain guide or timing chain guide material, but on elongated timing chains caused by premature wear--and, again, there is a STRONG correlation between oil change intervals and stretched timing chains on ALL cars. BMW is negligent because they recommended extended oil change intervals. There's way too much focus (here, and other forums) on the timing chain guides themselves. Again: ALL timing chain guides become brittle over time and with enough heat cycles. Yes, possibly, there was a bad batch of timing chain guides to further complicate/muddy the waters, but the numbers are statistically very small (only magnified on the Internet, as is common). Your call if you want to replace the timing chain guide to be safe, or simply roll the dice. Just be aware of how your car sounds. As preventative maintenance (on higher mileage engines), replacing the timing chain guide and timing chain is always a good idea if you want peace of mind down the road. Last edited by The Kurgan; 06-26-2019 at 10:35 AM.. |
06-26-2019, 02:34 PM | #57 |
Rep 8
Hey guys, didn't know where else to post.
Was debating getting a CPO 2016 428i Gran Coupe M Sport with 22k miles, great service records, for 27k. Seems like a good deal. Can the N20 engines last at least 150k miles? If I can't get 150k I probably wouldn't get it as I'd finance 5 years. I've read mixed things about the N20 engines. Although timing chain is apparently fixed in the 2016 Model? Was also debating getting a 2011 528i with 17,000 miles (weird, right?) sold by a BMW Dealership for 18k. I know the 2011 528i is more reliable due to no turbo but I also worry about it sitting too long since that's only an average of about 2,500 miles a year. Thanks for any feedback! |
06-26-2019, 03:27 PM | #58 | |
Rep 776
08-30-2019, 03:42 PM | #59 |
Rep 69
At 186K now and just installed the MHI big turbo to replace the leaky OE unit.
No other changes but WOW does she pull now. Also swapped out the suspension (Bilstein B8s and Dinan Springs/Camber plates) since it had >80K on it. Lastly, did all (3) engine mounts since they were TOAST. Idles so smoothly now, like its new all over again.
Mods: Stoptech Sport Brakes, Injen Intake, BMS Catch Can, AFE Downpipe & 328i Sport Exhaust, Evolution Raceworks Chargepipes, VRSF intercooler, AFE tBody Spacer, MHI Big Turbo, BM3 Stage 2 93 Octane tune, Bilstein B8 Sport+ dampers, Dinan Perf Spring Set & Camber Plates
08-30-2019, 04:09 PM | #60 | |
Rep 1,827
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
08-30-2019, 05:01 PM | #61 |
Just Copacetic!
177
Rep 616
Interesting and glad to read that body rust is not as issue. I don't know if any of you remember the "rust-gate" issue with the 2012/13 F30's that came with rust on the seat pans. I recall a customer in Korea who was so mad he actually drove up to his dealership and set his car on fire
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite |
08-30-2019, 05:03 PM | #62 | |
Rep 3,752
Never mind... your in New York Just want to say DAMN Sir |
08-30-2019, 08:06 PM | #63 | |
Rep 3,946
jh_f301306.00 |
08-31-2019, 07:09 AM | #64 | |
Rep 1,610
09-02-2019, 09:24 AM | #65 |
Rep 125
Am I the only one here who's surpassed 200K?
204,500 miles This is on an N55 (2012 335i, purchased new). Aside from routine maintenance (oil, brakes, brake fluid every 2 years, air filter, plugs at 146K), I have had no major issues. I replaced the VCG and OFHG at around 198K due to leaks, and I'm now dealing with what I believe to be a failed PCV. And I had a ruptured coolant line a couple of years ago. Everything else is original. So (knock on wood) I can't complain! |
09-02-2019, 12:44 PM | #66 | |
Rep 1,827
adhrp1292.50 |
