07-02-2021, 08:04 PM | #23 | ||
Rep 326
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
07-04-2021, 01:24 PM | #25 |
Rep 120
Drives: Bmw X5M, M6, X5 5.0, 335i
Final update. Car is running now as it should.
Hopefully this thread will help someone in future. I was able to move the wire harness over to my mechatronic unit. So I swapped the mechatronics and was able to connect it to the HIS (start stop cylinder). Reinstall the valve body filled with 7 quarts of fluid. No coding or any other actions required. Car fired right up transmission is shifting as should. It was jerky first few miles now it's fine. Little tip for everyone who plans to do fluid change or any service to the transmission. In last picture is the most cost effective, quick and easy way how to pump the fluid in. Forget crappy hand pumps it will take you forever leaving mess all around. This will transfer 5+ quarts in minutes while you just laying on your back |
Techno 9000518.00 |
10-12-2021, 10:30 AM | #26 |
Rep 3,947
Great work man.
I had a Clutch B disrupted code that came up randomly after a track day. No issues after that even on the track the next day. How did you get the car that high on the Quickjack? |
10-29-2021, 05:16 PM | #27 |
Rep 120
Oh that was a challenge. I'm trying to remember.
I think I lifted the car put spare wheels under the wheels lower the quickjacks back down insert the 2x4 and lifted the car. Took me some time to figure out. Bcs there was not enough clearance to put the 2x4 when the car was on the ground. You may use ramps instead of spare wheels or something else but make sure it's safe. |
10-30-2021, 02:24 PM | #28 | |
Rep 3,947
This would probably be the expensive way of doing it. |
10-30-2021, 05:50 PM | #29 |
Rep 120
Wow that's expensive. I was googling different ways how to do it and 4 car ramps seems the most cost effective way if you don't have something usefull laying around.
Also I'm planing to buy quickjacks extensions as the 2x4 cracking was making me pretty uncomfortable. But once you have all tools and equipment it's doable. Another pair of hands would definitely help but as my GF refused to go under the car in this sketchy setup. I had to do it myself. |
