06-29-2023, 11:49 AM | #1 |
Rep 17
Bad performance with MHD Stage2 on 435i N55
Hey guys,
I just flashed my 435i with MHD stage 2 (tried Stage 1 and was disappointed with the result so gave Stage 2 a go) and I am experiencing really subpar performance. Before giving MHD a go I was running an off the shelf map giving me 360hp/550nm - and wanted the features of MHD. My dragy 0-100kmh times dropped an entire second when doing this from 5.1 to 4.1. I’ve contacted MHD but was wondering if anyone here can see what could be wrong? Running 100 octane Shell Vpower fuel Stock IC and Stock down pipe BMS open air filter and alu charge pipe Log: https://datazap.me/u/kjaerulff/435i-...og=0&data=3-13 Dragy links: https://ibb.co/x1KgjR2 https://ibb.co/Byfdxv4 Appreciate it guys |
06-29-2023, 12:00 PM | #2 |
Rep 7,733
What tune were you running before? Do you have a log from that?
You shouldnt be running stage 2 without an IC. Really shouldnt even do stage 1. Your 100 octane is helping your timing but you are no doubt losing power with IATs skyrocketing to 140F. Boost is also quite a bit below target in 3rd gear for some reason. |
johnung4947.00 |
06-29-2023, 12:11 PM | #3 | |
Rep 17
Constantly monitoring my iAT and max I’ve seen is 105F, mostly quite below. But you’re right I was simply testing to see if I’d feel any power like I expected with stage 2; but just feels super slow…. Flashing back to Stage 1 later today! |
06-29-2023, 12:14 PM | #4 | |
Rep 7,733
harkes1113.00 |
06-29-2023, 12:19 PM | #5 | |
Rep 17
06-29-2023, 12:22 PM | #6 |
Rep 17
Wait; does flashing with xHP overwrite MHD?
Bloom_435i24.50 |
06-29-2023, 12:37 PM | #7 |
Rep 7,733
06-29-2023, 12:38 PM | #8 |
Noob
73
Rep 255
MHD flashes the DME and XHP flashes the TCU which is separate so no it doesn't overwrite MHD infact you can pair it with MHD and the next time you flash after you install XHP theres an option in the MHD settings to Flash your car with XHP installed.
FBO, MHD Stage 2+ E20, Xhp Stage 3
06-29-2023, 11:28 PM | #9 |
Rep 17
Alright still trying to get my old tune file for testing; but wondering if the MHD log indicates any problems with my car?
Flashed back to MHD Stage 1 an now gettin 5.4-5.5s times 0-100kph, which is slower than stock 🧐 |
06-30-2023, 01:24 AM | #10 | |
Rep 2,410
(A Dane in China) |
06-30-2023, 01:26 AM | #11 |
Rep 2,410
Try to load the Stage2 93oct map. All that timing correction is hurting performance more than running a little lower and consistent timing.
(A Dane in China) |
06-30-2023, 01:55 AM | #12 |
Rep 17
06-30-2023, 02:41 AM | #13 | |
Rep 2,410
Having more beer than you can drink = good. Having less =
(A Dane in China) |
06-30-2023, 11:00 AM | #14 |
Rep 7,733
The problem is your IC man. You absolutely should not be running these tunes without an IC. Your IATs go over 140F which not only hurts performance directly due to the air temp but its causing timing corrections even though your fuel octane is far higher than the map octane. You can only support like 5 degrees of timing.
06-30-2023, 09:05 PM | #15 | |
Rep 2,410
As I remember he is running a 102RON map on 100RON, hence I recommended him to run the 98RON map instead.
(A Dane in China) |
07-01-2023, 02:15 AM | #16 |
1318
Rep 3,593
Actually it can.. it will cause detonation 100%
2017 m240i xDrive 10.67@132.32mph w/bm3
07-01-2023, 01:58 PM | #17 |
Rep 7,733
He is running 100 octane fuel on a 95 octane map so his fuel is way higher than the map. I am not sure about the tune actually reducing timing targets based on IAT but it didnt look like it. The high air temp is also directly reducing power.
07-01-2023, 06:52 PM | #18 | |
Rep 4,980
He needs an Intercooler. Period. |
07-01-2023, 07:01 PM | #19 |
Rep 2,410
Yes 100RON fuel (we use RON in Denmark) on a 95AKI/102RON map
(A Dane in China) |
07-01-2023, 07:05 PM | #20 |
Rep 665
I don’t understand why people are buying tune first instead of hardware. It’s like buying a fillet mignon raw steak but have no bbq grill to cook it, how are you going to enjoy that fine steak?
I support being cheap, but please do it with risk management. Do you want to blow up your car just with tune without proper hardware? |
07-02-2023, 03:01 PM | #21 |
Rep 17
Thanks for all the feedback! Intercooler ordered; Wagner EVO 2.
Tried running 93oct maps and had no timing corrections; still bad performance. I guess in the end I don’t fully understand why my old tune (360hp/550nm) could easily give me good performance with no upgraded FMIC; but with MHD I need one to get good performance! Oh well - looking forward for the IC upgrade! I also ordered a custom tune for the car which will happen in a month from now; will update on results of both MHD tune with better FMIC and then the result of the custom tune |
harkes1113.00 |
07-02-2023, 07:22 PM | #22 | |
Rep 4,980
