04-08-2018, 10:24 PM | #1695 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
04-08-2018, 10:39 PM | #1696 |
Rep 698
So quick update so if not most there are bmw that have the drl dim even the new ones with lci when low and high beams are on. You can choose presets to increase the intensity by 10% increments via bimmercode and adapter. So people don't panic this is completely normal.Thought I research and share.
MSCD3184.50 |
04-09-2018, 12:05 AM | #1697 | |
Rep 92
F30 328i Mineral Grey Metallic, M Perf Kit, M Perf Exhaust, Matte Black Kidney Grills, H&R Sport Springs, 19" Velgen VMB5 Rims.
04-09-2018, 01:40 PM | #1698 |
Rep 698
Negative. I've now done more researched and have found out that by making the drl stay the same brightness when the low beams are off and keeping that same brightness when coded when low beams are on can age/damage the headlamps sooner because of the heat levels going up. So I decided to keep it the way it is its still clean imo and dont have any issues . The headlights do have the warming up flicker/volt check when turning on the car that ill most likely code off for sure. Hope this helps !
mhdelarosa6.50 JustTheNorm0.00 |
04-09-2018, 02:54 PM | #1699 |
Rep 2,382
Newest issue... So the issue wasn't the adjustor, but something with the lens maybe.. Projector will shift and lose focus, producing a floodlight, circular beam and then eventually bump back into the normal projection..
04-09-2018, 03:31 PM | #1700 | |
Rep 698
I read u mentioned previously about the cutoff adjusting coming off the rack? When I tried adjusting vertically on the passenger side to put it higher as oppose to the driver side being high already. Tje passenger felt a bit of a tension and wasnt sure to keep going so I just slightly adjusted back and kept the cut off lines more in the lower side instead of the middle hood height. Will it be safe to keep going ? Or how will I determine how far I can turn the adjuster ? |
04-09-2018, 04:02 PM | #1701 | |
Rep 2,382
As for my issue, yes. I've had the lights for over a year with no issues up until a couple months ago. I thought it was the bulb holder at first, but fiddled with that and couldn't get it to focus. No play on the holder itself or the bulb. I have a feeling that it's the lens or reflector. Possibly separating? I might just give up and if I can't find a drivers side headlight, I may have to breakdown and buy a new set. :/
04-09-2018, 04:24 PM | #1702 | |
Rep 698
04-09-2018, 04:27 PM | #1703 | |
Rep 2,382
04-09-2018, 05:14 PM | #1704 |
Rep 698
Lol yup there's a trick to it though just try to grab the bottom piece and lock it. But I'm sure u figured it out Hahaa. Luckily I don't have big hands . I'm 5'3 and works for me no power tools required lol.
04-09-2018, 11:11 PM | #1705 |
Rep 2,382
The hardpart was turning that nut in such a tiny place lol.. Agonizing 5 minutes lol.
04-11-2018, 11:36 AM | #1706 |
Rep 131
Hey man I just got my lights in today I swapped out the bulbs for the diamond vision and was wondering if I’m supposed to leave the seal on the cap to cover up the back part of the head light?
04-11-2018, 03:35 PM | #1707 |
Rep 2,382
Yes. Ensure the o-ring stays around the cover. This is paramount to sealing it from the weather and condensation.
04-15-2018, 08:40 PM | #1708 |
Rep 4,031
So Kies Motorsports came back to adjust the lights... used some washers somewhere behind the lights... I think it looks much better. Really happy with the result! Before and after... I really appreciate Bryan and Cliff coming out. Great customer service.
Edit the app flipped the photos... before is lights on.
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
04-15-2018, 09:01 PM | #1709 | |
Rep 2,382
04-15-2018, 09:09 PM | #1710 | ||
Rep 4,031
04-15-2018, 10:03 PM | #1711 |
Rep 2,382
You think you could do roughly the same angle as the before picture? I think the difference in angles makes it hard to tell that there was a change. Curious if it's worth going back in there. I just pulled my middle down some to match it.
04-15-2018, 10:10 PM | #1712 | |
Rep 4,031
04-16-2018, 09:59 AM | #1713 |
Rep 90
Still looking for the LCI version headlights. Cannot get USR to respond and I contacted DEPO and they said they would have someone reach out to me but that has been a few weeks ago.
I found these but never heard of the site or company. Any thoughts? https://www.betaautoparts.com/produc...3-oe-original/ https://www.betaautoparts.com/produc...4-oe-original/ |
04-16-2018, 10:14 AM | #1714 | |
Rep 2,382
04-16-2018, 10:35 AM | #1715 | |
Rep 90
They are in the UAE. I also sent an email to Hella directly cause I didn't see them on their webpage. Really would like to keep my car with the right parts. I could go with the pre LCI Depos but still trying to find what would have come with my car. |
04-16-2018, 10:37 AM | #1716 |
Rep 2,382
LCI looks really good as well, so I don't blame you. Plus, you can go LED with them since they're reflectors. Much easier to install lol.
