05-27-2021, 09:59 PM | #1 |
Rep 91
B58TU1 HPFP Woes, Odd Drivetrain error, Possible Sensor Issue?
So, basically I installed the B58TU1 pump. I messed up the install a bit (sheared one of the screws https://f30.bimmerpost.com/forums/sh....php?t=1802494), and had a BMW dealership fix it. I've been getting these issues since.
Now here's the issue. The car will go into limp mode and throw a drivetrain issue error. The actual codes and situations in which they are thrown: 1. Cold start It will go into limp mode after ~2-3 minutes of idling after the cold start high rpm idle finishes. 11AC02 - High pressure fuel system, plausibillity cold start: Pressure too low. -DME shadow (inactive) codes - 11A030 - Low-pressure fuel system, electric fuel pump, adapation: Adaptation value outside valid range. 11A401 - Fuel high pressure during fuel injection release: Pressure too low 11AA08 - High-pressure fuel sytem: Pressure reduction too high 11B401 - Fuel high pressure or after enabling injection (2nd ambient condition set after delay): Pressure too low 21A026 - Combustion engine: Abnormal ignition key or automatic engine start-stop function start detected If I clear the code using MHD, it will raise the idle RPM out of limp mode, and then operate normally. If I delete cold starts using MHD, the car will idle fine, and not throw any codes. 2. 8th Gear ECO mode When releasing the throttle in 8th gear in ECO mode, ECO mode will drop the RPM while coasting. This causes a drivetrain error for me 3. High throttle pulls at 6th and 8th gear, at near or full throttle, I will throw a drivetrain error around 4000 RPM. If I clear the code using MHD, I can generally continue driving at high-speeds without issue. -------------------------------------- Is this a sensor issue? It seems unlikely as it happened after I botched my initial HPFP install and had it fixed. It's just very bizzarre however. I can run the car normally 90% of the time, and only get these drivetrain failures on occassion. Is this a LPFP issue? I don't see any fuel leaking at the HPFP, and I checked the LPFP line and it's torque'd properly, but I did note that code regarding the LPFP adaptation value
2018 BMW 340i GT | BMS Intake | Autowerke Catted DP | MHD E40 Mix Stage 2+ Tune | FX-150 HPFP
05-28-2021, 01:03 PM | #2 |
Cheapskate
4445
Rep 4,993
Do you have any logs? If you have a lpfp issue then it will also show low hpfp pressure codes. So to me you should start by addressing the lpfp code.
05-28-2021, 03:50 PM | #3 | |
Rep 91
https://datazap.me/u/cxmplex/drivetrain-malfunction?log=0&data=4-27 |
05-28-2021, 03:52 PM | #4 |
Rep 91
Looks like not enough pressure is being reached? Only code thrown this time was 11AC02. After clearing it, I got the shadow code 11A030 for the LPFP.
If this is due to a bad install, what exactly would cause a lack of pressure? Is it alignment of the pump? One of the rail attachments? Or could it be a LPFP issue causing the HPFP to not have enough pressure? Could this just be a bad OTS map? The required pressure seems a little strange to me. Last edited by cxmplex; 05-28-2021 at 04:07 PM.. |
05-30-2021, 07:30 AM | #5 | |
Cheapskate
4445
Rep 4,993
Do you hear the fuel pump prime when you start the car? Should sound like an electronic whirring sound. |
05-30-2021, 03:18 PM | #6 | |
Rep 91
Do you know if I can claim the parts warranty on this HPFP if that ends up being the issue? I’m guessing no since I installed it in a car other than the one it was intended to be in. Also, yes I can hear it priming, I often let it prime for a bit to help with these issues I also have another sensor on its way just in case. |
06-01-2021, 08:22 AM | #7 | |
Cheapskate
4445
Rep 4,993
06-01-2021, 12:07 PM | #8 |
Rep 91
Technically yeah. I bought it from getbmwparts, and they’re technically a dealer I believe. Also when actually driving the car, my required pressure is matching my actual pressure. It’s only idle and 8th that gives me issues.
06-04-2021, 11:12 AM | #9 |
Rep 844
Do you still have your old fuel pump? Could you swap that back in and retune and see if the problem goes away? That would allow you to eliminate the fuel pump as the issue.
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
02-04-2022, 06:28 AM | #10 | |
Rep 22
Experiencing same atm. First it was related to misfire and now throwing error 11A030. Have you managed to fix it? I am thinking about fuel tank ventilation system. |
snifflz13.50 |
10-19-2022, 03:22 PM | #11 |
Rep 110
