07-18-2019, 12:42 AM | #1 |
Rep 14
Anyway this will fit???
I have come across a good deal for some Rohana RFX wheels. However, they seem a little too wide and I need some help to confirm. The fronts are 19x9.5 w/35 offset and the rears are 19x11 w/28 offset. The previous owner said it rubbed the rear struts when he tried to install on a 335d. Anyway this would fit on a 4series oem msport suspension.
07-18-2019, 01:49 PM | #2 | |
Rep 4,314
https://f30.bimmerpost.com/forums/sh...7&postcount=26 however if you put a 295/30/19 on the 11" rear, the rear tires will be at 13mm more poke on where it is on this F36 with 295/30/19 ET40 on the rear. sorry you'll have to go to 2.00' in the vid to see the poke. imo, it'll be poking way too much since the F36 in this vid is already poking(appears about 12mm). i'm guessing on a 19x11, ET28 with 295/30/19 the poke will be about 1". definitely not my cup of tea regarding appearance. https://f30.bimmerpost.com/forums/sh....php?t=1634712 fyi increasing the rear track 38mm wider(than OEM) and having that much grip in the rear, if you install 295's, will increase understeer and wide heavy tires will cause your n20 to feel like an absolute slug. if you don't care how it affects your handling and performance and don't mind the appearance, then have at it and post pics after it's installed. Last edited by alohasurftoad; 07-18-2019 at 01:55 PM.. |
07-18-2019, 02:10 PM | #3 |
A family of bimmers
2745
Rep 7,741
it's always a good deal when it dont fit
alohasurftoad3067.50 1QuikWS61618.50 |
07-19-2019, 07:20 AM | #4 |
Rep 963
Not without camber arms & a lot of stretch, rolled arches, etc.
https://f30.bimmerpost.com/forums/sh...postcount=1563 - these rears are 20x11 et20 - yours will only poke 8mm less than that |
