01-17-2019, 08:02 PM | #1 |
Rep 81
Msport Xdrive spring rates question
I have a F32 xdrive with normal/nonsport springs. I'm installing Koni active shocks soon and would like to install slightly stiffer springs at the same time, so I'm considering a set of OEM msport springs. Can someone tell me if I would simply be swapping springs with the same rates or if this is what I'm looking for?
I think stock rates are 160lbs front and 486lbs rear, and I would like to find 10-20% stiffer springs. It seems very hard to find actual numbers especially for msport springs. From what I can gather scouring the forum, msport springs are a somewhat higher rate than normal springs for non-xdrive F30/F32 cars. However, there seems to be very little info if the same is true for xdrive cars. Anyone know? |
01-18-2019, 02:16 PM | #2 | |
Rep 125
01-18-2019, 07:22 PM | #3 |
Rep 3,540
I don't think the stock rates are that high. Eibach springs are 29N/mm (165lbs/in) front and 86N/mm (491lbs/in) rear for your car and are noticeably stiffer. The difference between that and the numbers you think might be stock is within the error tolerances of lots of springs.
01-19-2019, 10:31 PM | #4 |
Rep 81
Here are the only rates I've used for comparison:
M3 E90 160lbs front, 550 lbs rear M4 F82 185lbs front, 575 lbs rear BMW Comp M4 198 lbs front, 685 lbs rear Dinan F32/82 250 lbs front, 650 lbs rear Swift F32/82 279 lbs front, 726 lbs rear All that info came from various forums and could very well be totally wrong. I do not want anything nearly as stiff as those aftermarket springs listed, and I use my car as a daily driver in the snow, so I cannot afford much of a drop. That seemingly left me with two choices to try; 1. M4 OEM springs, or 2. Msport F30/32 springs. I posted before asking if the M4 springs fit, but no one knew. All I'm trying to determine now is if the Msport xdrive springs are actually any higher of a rate or if the non-xdrive will fit, However, if you have a suggestion for springs that will slightly (20%ish) stiffen without much of a drop I would greatly appreciate being steering in the right direction. |
01-19-2019, 11:33 PM | #5 | |
Rep 3,540
01-24-2019, 08:08 PM | #6 | |
Rep 81
I didn't realize these existed before you mentioned it, but I'm going for it. I have a set of M4 springs and F32 koni special active shocks ready to go on, but I think the M4 springs will lower the car by about 1". I'd love to counteract about half of that with a riser/booster but can't seem to find any F30/F32 specific ones in anything but stock thickness. |
01-24-2019, 08:52 PM | #7 | |
Rep 3,540
