01-13-2019, 10:11 PM | #1 |
Rep 6
VRSF Chargepipe install help
Hi, I'm attempting to install a VRSF Chargepipe in my 2015 335xi. I was able to get the stock Chargepipe out through the top, but I can't get the new one in through the top or bottom. I can't seem to get enough clearance to get it in. Any suggestions? Thanks.
01-14-2019, 04:32 PM | #4 |
Rep 190,614
All good OP?
Bpdev3.00 |
01-15-2019, 10:07 PM | #5 |
Rep 6
Yup, thanks guys! It was much easier to install by installing the top half first and then connecting the bottom.
I also ordered and installed the vrsf 5" FMIC. My only complaint is I ordered it in December and still got a defective one with Fan tabs too long and no screws included. I was able to bend the tabs in good enough though. |
upsidedownfunnel1996.00 dr.roro195.50 |
01-16-2019, 06:37 AM | #7 |
Rep 6
01-16-2019, 09:25 AM | #8 | |
Rep 115,980
Mike |
Bpdev3.00 |
01-16-2019, 11:19 AM | #9 | ||
Rep 6
01-16-2019, 01:51 PM | #10 |
A family of bimmers
2745
Rep 7,741
yea. i ran in to the same thing. i fished it down from the top with the silcone sleeve loose and then from the bottom reached up to rotate the clamps around to tighten down enough.
if i had to do it again id do the two piece and be done in half the time.
01-16-2019, 02:48 PM | #11 |
Rep 115,980
01-16-2019, 02:57 PM | #12 |
Rep 40
01-17-2019, 04:35 PM | #13 |
3441
Rep 79,212
01-17-2019, 04:50 PM | #14 |
2093
Rep 43,350
Vacuum port locations, pipe routing and a few other details differentiate the four different styles of F chassis N55 cars which is why unfortunately we're limited to 4 different pipes for one car.
We're actually in the process of compiling multiple 3d scans of each engine bay in order to find a one pipe fits all solution and I'm happy to say we're pretty close launch. We'll have an update shortly! Last edited by Tiago@VRSF; 01-17-2019 at 06:09 PM.. |
01-18-2019, 12:41 PM | #15 |
Rep 115,980
01-18-2019, 12:44 PM | #16 | |
Rep 115,980
This is amazing.... Great idea.. If you get this done that will be awesome.. Always great to have a universal fit.. Both from a vendor and end user perspective. Mike |
01-30-2019, 06:32 AM | #17 |
A family of bimmers
2745
Rep 7,741
Brilliant idea! so long as the sensor and vacuum line locations fit without adding anything that would be awesome. Im not sure how a rwd and xi would be able to use the same since all the awd components create an issue. Curious to see the outcome of this.
02-10-2019, 11:01 AM | #18 |
Rep 19
How long start to finish did the chargepipe take for install?
02-11-2019, 10:19 AM | #19 |
Rep 115,980
