01-13-2019, 11:40 PM | #1 |
Rep 379
2016 328i Getting different noise while driving
Hi guys .. i have a 2016 328i with M sport option ... lately i have been hearing a different noise appears to be coming from the engine bay ... sounds like the noise when window is open slightly. The noise is more noticeable while driving on a soft tarmac b/w 40 to 50mph. I have attached the video below ... can you please hear that and let me know what could be the reason.
some weird noise like zigzigzigzig ... more clear from 30secs in the below video https://youtu.be/OpFiziHms2g Thanks, Kishore. |
01-16-2019, 06:59 AM | #2 | |
Rep 379
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
01-16-2019, 05:59 PM | #4 |
Rep 379
It feels more like air noise especially if i keep the vehicle constantly at 40/45mph.
01-16-2019, 06:16 PM | #5 | |
Rep 552
You say it's coming from the engine? Check the engine to see if anything, intake pipes etc haven't come loose. No loss of power? |
01-17-2019, 10:25 PM | #6 | ||
Rep 379
I tested those options and seems to be tires issue... I changed my tires around 8months back and noticing this issue from last one month after a long drive.
01-18-2019, 02:41 AM | #7 |
Rep 552
What tyres do you have?
Run flats do have tyre roar depending on speed and the road surface. On smooth roads they are relatively quiet but on rough roads the noise is loud. Maybe this is what you are experiencing Run flats are one of the worst ideas. The likelihood of getting a flat is unlikely but then you have to live with the noise. |
01-18-2019, 10:40 AM | #8 | |
Rep 379
01-20-2019, 10:20 AM | #9 |
Rep 66
Have you tried rebalancing your wheels? Do you notice any unusual vibrations while driving?
1985 Pontiac Trans Am - LS swap loading...
2005 Pontiac GTO - Sold 2015 Subaru WRX - Sold 2014 BMW 335i M Sport 2022 Toyota 4Runner - Dadmobile |
01-20-2019, 10:30 AM | #10 |
Rep 4,876
My 340 had a bad wheel bearing that gave an odd rumbling noise that sounded just like when my last car had a wheel alignment issue. Hard to tell from the video though.
If you jack up the front and spin the wheels, one didn't spin as smooth. |
01-20-2019, 10:43 AM | #11 |
Rep 379
Yes rebalancing done. No vibration, but i feel slight flex in chassis side to side even for a very small bump.
01-20-2019, 10:52 AM | #12 |
Rep 379
Ok ... I will try to jack up and spin the wheel.
01-20-2019, 01:24 PM | #13 |
Rep 4,876
My case was something they call "rail bearings". If the car is shipped by rail, and one of the needles in the wheel bearing is sitting in a certain way with no grease, you get a electrostatic arc that scores the needle. It would be a warranty item.
01-20-2019, 01:27 PM | #14 |
Rep 379
Thanks for that information... i have booked an appointment with dealer for feb 5th let's see what they find out.
